Click for Walker Click for Perko Click for Burger Click for Nordhavn Click for Northern Lights
Throttle lever tension
Discussion in 'Carver Yacht' started by Piper, Sep 6, 2014.
  1. Piper
    Piper New Member
    Kingston , Ontario
    My Carver Riviera has the same stock throttle levers found in most 1980's Carver's
    One lever has just the right amount of tension and feel. By that I mean the lever stays in it's set position regardless of the movement of the boat and can generally resist any glancing arm movements as I reach for other instruments. It takes light but firm hand pressure to make any adjustments. The other lever on the other hand always sees sloppy and loose in comparison. One finger can adjust it, and it can also easily slip out of position.
    I'm just wondering if there is any point in the system where a tension adjustment can be made?...in the lever mechanism under the dash?, in the throttle cable itself?....at the carburetor perhaps? Or do I just have to replace the throttle cable itself and hope that a new one will provide more tension?
    Any suggestions would be greatly appreciated.
    Piper
    Assuming cable controls, by the engine end of the cable there should be a clip holding the cable case. This often slips off. The result can be what you describe or no response at all. Another possibility is a stretched/ breaking cable. Check that the clip is attached, and then have someone move the throttle while you check the reaction at the motor end.
    I seem to recall seeing a tension screw on certain types of throttle handles, but I doubt that's your situation.
