Click for YF Listing Service Click for Nordhavn Click for Northern Lights Click for Walker Click for Ocean Alexander
Thoughts on sandblasting my wheels
Discussion in 'Props, Shafts & Seals' started by tbaxl, Nov 22, 2020.
  1. tbaxl
    tbaxl Member
    Gulf Coast
    Wheels are off for cutlass bearing change so it is time to re do my antifouling. I am 99% sure they do not need to be checked as there have been zero issues felt and they look perfect with exception of the prop speed. Can I sandblast them to clean the up or is that a bad idea.
    Tim
  2. MBevins
    MBevins Senior Member
    Windsor On. Canada
    My initial reaction is no it's not a good idea. I suspect you'll damage the edges.
  3. tbaxl
    tbaxl Member
    Gulf Coast
    Not really worried about edge damage as much as heat and warping. Have already decided I will just chemically strip and hand sand.
  4. Norseman
    Norseman Senior Member
    Palm Coast, Florida
    Soda blasting may be an option?
    Had my bottom soda blasted 2 years ago, gentle on the gelcoat.
    (I should specify, the Boat’s bottom was soda blasted, not mine) :cool:
  5. MBevins
    Windsor On. Canada
    You are correct, I was referring to warping when I mentioned the edges, just didn't clearly state that.
  6. rtrafford
    rtrafford Senior Member
    Vero Beach
    The prop shop will sandblast them when you drop them off for repair. Sandblasting is fine if you're careful. Soda is safer.
  7. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    As above, Soda blasting.
  8. CaptTom
    CaptTom Senior Member
    Palm Beach to Ft Lauderdale
    Would a wire wheel on a drill work? I've seen some shops do it that way before antifoul paint.
