Click for Northern Lights Click for Cross Click for Ocean Alexander Click for Delta Click for Westport
Tender Question
Discussion in 'General Yachting Discussion' started by Nashbrent, Nov 19, 2012.
  1. Nashbrent
    Nashbrent New Member
    Port Everglades
    Looking at a 13' Boston Whaler as a tender. Problem is it will be on my transom and will protrude out about a foot on eash side although not my beam at mid ship. Is this a big deal? I know it will be a bit of an issue while docking.
  2. AMG
    It depends a little on what boat you have, but I wouldn´t do it. Also consider the engine adds a feet or two...
  3. Pascal
    A foot per side is a lot and going to be a PIB not just when docking but also just using the platform, in the slip etc
    A 13' whaler is pretty heavy for a boat with so little beam.
  4. Nashbrent
    Port Everglades
    45 Shannon Voyager. 15ft. beam at midship droping back to 12'4" at the transon. 1200 lb Nick Jackson transom lifting davit. Weight is no prfoblem. The boat likes a little weight of the rear end. I've thought abot a 11 Whaler... its just the 13 is so much more of a functional boat. It will serve as my taxi in Ft. Lauderdale/Keys. Any other suggestions?
    Thanks for the response!
  5. Kafue
    Kafue Senior Member
    Gold Coast Australia
    Tow it!
    You are looking for trouble at every dock you visit, Plus the stress.
    Imagine going in to the fuel dock or any marina slip. You will probably end up dropping it in and towing each time anyway.
    I have a 13' Boston I tow, I agree they are absolutely great, but the trouble would make the 11' a better choice.
    Good luck.
  6. franzmerenda
    franzmerenda Senior Member
    La Spezia, Italy
    As far as I know, Boston Whaler has also an 11 footer in production...
  7. PropBet
    PropBet Senior Member
    Is Everything!
    Tow or downsize to the 11. Not only have the issues been pointed out cosmetically, but functionally as well.
  8. Silver Lining
    Silver Lining Member
    Chesapeake/Florida
    I have a 11'6" RIB with a 30hp. My Viking SC is 15' beam midship and ~13 ft at the transom. With the enigine down it is ~12'6" which is the is the maximum safe width. You really dont want the engine hanging off while docking stern to for the obvious reason, same for a side tie, but when leaving the dock, hooking a pylon could be even more troubling.
  9. Nashbrent
    Port Everglades
    Good point! Never really considered hooking a pile pulling out. I usually do most of my damage backing in.
  10. PropBet
    Is Everything!
    is that why the dink is there to act as a fender?
    (I kid.... I kid...)
    :D
  11. CaptTom
    CaptTom Senior Member
    Palm Beach to Ft Lauderdale
    Oh man, I had it all wrong. When I saw the thread title of "Tender Question", I was thinking more of "Will you respect me in the morning?" :D
  12. Nashbrent
    Port Everglades
    Yes I will Captain Tom.
  13. CaptTom
    God, I hope you're not a dude. lol
  14. Pascal
    The big issue with the overhang will be when coming in and out of a stern to slip. Most of the time, If you're pulling out of a side tie bow first you re asking for trouble, tender or not
    Towing is even worst of a pita, you need someone to deal with the tender whenever you are in close quarter. Especially a whaler which will require fenders unlike a rib
    An 11' whaler is a joke as a tender, as capacity is 3 or 4 persons at the most. The last 13' whaler I ve had to use ( 5 years old) had a flat bottom with no sump and always had an inch of water sloshing around Stupid design
    I also have to wonder how easy it will be to get a 13' whaler back on the stern lift in anything but dead calm conditions
    And then you have the fact that new whalers only come with those awful mercrappers... i ll take a RIB with a Yamaha any day!
