Click for Abeking Click for Burger Click for Mulder Click for Cross Click for YF Listing Service
Technomar 90 with Arneson Drive Furuno AP rudder reference bad
Discussion in 'Technical Discussion' started by marinemods, Nov 10, 2018.
  1. marinemods
    marinemods New Member
    I am getting incorrect rudder reference indication on both the Furuno NavPilot LCD Display and Analog Display. They read the same but it seems there are dead spots when turning stb to port and back. I am assuming it is the Rudder reference sensor however I am unable to locate the sensor. The boat has Arneson drives. Anyone have any idea where the rudder ref signal comes from?
  2. T.K.
    T.K. Senior Member
    Cairo - Egypt
    The rudder reference sensor will certainly be on the rudder table, either fitted to a steering arm between both rudders or fitted to one of the rudder actuators if your rudders are not connected together with a steering arm.
  3. marinemods
    These are Arneson Surface Drives (no rudders). From what I understand any sort of trim sensors are connected via mechanical cable to the inside engine room.
  4. marinemods
    Moving along ... found what I am assuming is the turn position indicator made by twin disc p/n 1020316. It is essentially a geared 2K Pot center tap. I found one of the wires lose when I connected it it goes 20 Deg Port when I am hard Stb and center is right on 0. It look's like someone has been in the unit and played with it. Does anyone have any documentation on this? TIA
