Click for YF Listing Service Click for Glendinning Click for Burger Click for Ocean Alexander Click for Perko
Tachometer quit working
Discussion in 'Post Yacht' started by JFpost, Feb 8, 2026.
  1. JFpost
    JFpost New Member
    Virginia
    I have a 1978 Post with 6-71 ( non -turbo) and the port side tach quit working. I replaced with new tach and still not working, not getting a signal to it. Anyone ever have an issue like this? I’m sure with some tracing the wire down I can figure it out, was hoping someone may have had this issue before.
  2. MBevins
    MBevins Senior Member
    Windsor On. Canada
    Is it getting feedback from the alternator?
    Quite common.
    JFpost likes this.
  3. Capt Ralph
    Other than the alternator, the 6-71 usually uses a maniacal tach pick-up for the electronic tach.
    Question one; Do you use a mechanical engine synchronizer? Is it workings?
    If no synchronizer, you may find a tach pick-up on the back of the engine with a couple of wires to it.
    There are other ways to get a a signal to the tach.
    Including a pic-up on the front pulley or even a tap in the bell-housing.
    Let us know what you have to help save time to help.
    JFpost likes this.
  4. JFpost
    JFpost New Member
    Virginia
    It isn’t. Just drops to zero..
  5. JFpost
    JFpost New Member
    Virginia
    So I do use a mechanical synchronizer and it works fine. The port side tach was bouncing around and then just stopped, so I replaced and wired up same exact way but it does t respond at all. Starboard has no issues. Thank you
    Lets try again.
    Not an alternator feed?
    Synchronizers are working. Is there a tach sender on the sync box ?
    Or somewhere else?
    Lets identify the tach sender and troubleshoot from there.
  7. JFpost
    JFpost New Member
    Virginia
    Honestly I will have to look ( sync box) that’s a great question. When I was trying to trace the wires I didn’t even look at that, I will be back in town this weekend and hopefully will have a chance to look at that. I will also try and get a few pictures of the tach, alt as well..I am not sure if alt or elsewhere. I am familiar with diesel engines ( trucks) and while mostly the same, I realize there are some differences in the marine diesel and I am still playing catch up on the electrical and a few other things. I certainly appreciate the help and will look at that and respond back. Thank you
  8. Capt Ralph
    Detroits are great engines. NOT a lot of wires go to them..☺☺
