Click for Perko Click for Mulder Click for Mulder Click for Westport Click for Ocean Alexander
Synthetic Oil question
Discussion in 'Technical Discussion' started by Riverdance, Nov 22, 2014.
  1. Riverdance
    Riverdance Member
    Annapolis/W Palm Beach
    I have a pair of 480 hp Volvo diesels in my boat. I am considering using Mobil 1 synthetic for my next oil change.
    I have my oil changed every 50-65 hours now, probably overkill, thinking going to 100 hours with Mobile 1.
    I never see Mobil 1 used in boats but auto diesels use it. Cost?
    What am I missing?
  2. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    Nope, the new semi-synthetic oils are good for a year, but it is a year. Don't push it.
    Your engines will put pollutents and nasties into your oils and lubes.
    Change your oil . Always.
  3. Fishtigua
    Guernsey/Antigua
    Edit to Add
    I have a Lawyer client whose name ends with ....bergstein. His oil is magical. No, really, never needs changing.
    2 new long-blocks on order.
  4. SeaEric
    SeaEric YF Historian
    out on the dock
    I'd stick with the oil that the engine manufacturer specifies. If that's Mobil 1 - go for it.
  5. olderboater
    This comes up a lot and I'm with you, Eric. My answer to any "is it ok, should I" question is what does the owner's manual on that engine say, or what does the manufacturer say.
    I'd ask this too. What have you been using? Why are you making a change?
  6. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    My Man engines use Mobil 1 Delvac 5-40w. Except the first oil change good for 400 hrs. Expensive oil at $40 gal. Be sure to use synthetic that is made for diesels.
    I don't think you will gain anything by going to Synthetic and changing your oil every 50-60 hours is overkill 1 year or 100 hours is a good number. MAN's use synthetic as Cskip has posted. MAN recommends 1 year or 400 hours change interval on them, on pre-common rail Man's they recommended 1 year or 200 hours with traditional oil.
  8. Riverdance
    Riverdance Member
    I like the benefits of the Mobil 1 Delvac 5-40w listed on their site. All my cars come with Mobil 1. I just bought a diesel car that has Mobil 1 init which gave me the idea.
    Volvo maintenance schedule for my engines lists oil changes every 50 hours which is 3 times a year for me.
    The Volvo dealer in FLL says it is a better lubricant but the oil change intervals should not be extended.
    I will ask them to use the Mobil 1 this time and see how it goes.
  9. Capt Ralph
    Ouch..
  10. Capt J
    At a 50 hour change interval I wouldn't switch to Synthetic. You're looking at over double the price in oil. What oil temps do the motors run at? Does it show on the display. That's the only advantage I've seen of synthetic is it will usually run at a lower oil temp. Synthetic does have a tendancy to make older seals leak that haven't leaked before.
  11. Beau
    Beau Senior Member
    Beaufort, NC
    I use delvac 1640, expensive stuff, but recommended by Man for my 820's. I change every 100-125hours which is just about every October for me, always with new filters.
  12. jhall767
    jhall767 Senior Member
    Middle River MD
    Are you sure about that? Every volvo manual I've ever seen is at least 100 hours or once per year. Sounds like you are getting ripped off.
  13. Riverdance
    Riverdance Member
    Woops, I mis read the schedule. Yes every 100 hours or once year.
    Speed reading I noted: change oil & filter on the reverse gear for the first 50 only.
  14. Capt Ralph
    Now, what oil did the manual say to use.
  15. chesapeake46
    chesapeake46 Senior Member
    Another thing to consider is that once you are using Synthetic oil, you have to stay with Synthetic oil. An oil sales guy told me that so, take it for what it's worth ! :rolleyes:
  16. Capt J
    That mindset has changed over the last 5-10 years. The old mindset is that you cannot mix conventional and synthetic and once switched to synthetic that you shouldn't go back. Now either the cat is out of the bag (remember Mobil 1 used to have the synthetic oil market locked down solid for 15 years) or they have figured out there is no harm in switching back and forth or mixing the 2. You see a lot of car manufacturers using "semi-synthetic" which is conventional oil with some (the amount nobody knows) synthetic oil mixed in. Some motors the manufacturers state you MUST use only synthetic such as the Man Common rails (corvettes were the same way and that was due to oil temperature). The synthetics do tend to run a cooler oil temperature than conventional oil, and pour better at very low temperatures. They do tend to favor longer drain intervals. Such as Man common rails are rated to go 400 hours before changing the oil, the pre-common rails (same engine internally for the most part) they rated to go 200 hours. However synthetic also does have a tendancy to make seals leak on older motors that never leaked before and the price is about double for the Mobil delvac synthetic over conventional. Ring wear seems to be the cause of most marine rebuilds and I think that is oil related, but many times the bearings are in good condition and not changed during a marine diesel rebuild. Honestly, I've seen no excessive wear by using standard motor oil and changing it and the prescribed intervals in motors that synthetic is not required by the manufacturer. I generally almost always use the manufacturers oil in yachts and vehicles and feel you cannot go wrong with the oil they have blended for their engines and find the price is not really much more than going with some other brand.
