Click for CL Yachts Click for Glendinning Click for Walker Click for Abeking Click for Ocean Alexander
SubZero ice maker stopped making Ice.
Discussion in 'Technical Discussion' started by Mysteri, Jul 11, 2017.
  1. Mysteri
    Mysteri New Member
    Poughkeepsie
    1998 SubZero freezer works great but, this weekend the water flow stopped. Noticed the timing on the gear is always in the same place, just past the heating point. Does not open to add water. Any suggestions?
    19 years old???? I would verify the temperature of the freezer, if it's not cold enough it won't make ice, but it's probably the mold assembly.
  3. Iknownothing
    Iknownothing Member
    Lauderdale
    If the gear isnt moving, the motor is not getting power or it's burned out. Check for power, should be a few test ports right below the gear.
    The solenoid to allow water is controlled by the timing gear, so you won't have power there unless the gear is in the proper position.
  4. justold
    justold Member
    new jersey , fla
    completely thaw the unit , make sure the ice maker is thawed and then refreeze .
