Click for Abeking Click for Burger Click for Mulder Click for Walker Click for JetForums
Stiff Helm / Steering
Discussion in 'General Yachting Discussion' started by retiredguy, Dec 10, 2021.
  1. retiredguy
    retiredguy Member
    InTransit
    As most know I've an older Burger 63' that I am living on and bringing back to life. She has "chain and cable" steerage that is stiff, by that I mean it takes more effort than I like to move the wheel.
    I have lubed pretty much everything from the helm to the rudder shafts but steering remains stiff. Is that just the nature of this type of steerage or is there something else I can look into? FYI: Rudder bearings were checked by a pro while she was on the hard two months ago. No issues found.
    Thoughts?
  2. Pascal
    Surprised a boat that big doesn’t have hydraulic steering. Maybe time to convert to hynautic? On a 63 footer it doesn’t even have to be power assisted.
  3. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    I had cable steering on my Matthews.
    I had to methodically start from the helms , I had duel stations , grease every pulley from start to finish to keep it loose and free.
    Some pulleys where kind of hidden and took effort to get to them . Especially the corner pulleys .
    Any way with a bright narrow beam flash light, follow all the chain and cables and lube away.
    The ones you can’t reach you can tape a chip brush to a pole loaded with grease and work it around with the brush.
  4. rtrafford
    rtrafford Senior Member
    Vero Beach
    I'm betting it's a bearing on the rudder shaft binding. At the dock, if so inclined, disconnect the steering tie bar so that the rudders are independent. Move them back and further and compare the two in terms of stiffness or binding. Likely you find one is "locked up". Reconnect and coordinate for haul. On the hill, drop both rudders and replace both bearings. Yard will cut them for removal, and then freeze the new replacement bearings prior to pressing into place. Have the rudder shafts checked for straightness. Perhaps one has been bent in a previous impact. Most likely culprit is failure of one (or both) bearings that distorts the passage and binds the shafts. Replace the bearings, and she'll steer like new.
    TahoeJohn and cleanslate like this.
  5. rtrafford
    Vero Beach
    And, while doing this on the hill, spin your wheels by hand and compare. You may find a similar issue with the shafts. Metal boat, bronze bearing...corrosive buildup often caused with age and idleness.
    cleanslate likes this.
  6. cleanslate
    Cherry Hill, NJ
    I knew it…was just holding back …
    Lol
    Extremely informative, knowledgeable.
  7. retiredguy
    retiredguy Member
    InTransit
    Been thinking along the same lines
  8. retiredguy
    retiredguy Member
    InTransit
    Like the idea of splitting them apart to check again but as I said, the rudders and bearings were just check when she was on the hard. Not that checking is a guarantee...
  9. retiredguy
    retiredguy Member
    InTransit
    I was thinking the same, I may not have gotten every place I needed to get.
  10. rtrafford
    Vero Beach
    If the bearings were checked without disconnecting the arms, they could only have been checked for horizontal play. That’s not your problem. Your issue is rotational, that the bearings are compressing against the rudder post (or one or both rudders are bent. That issue will FEEL like a good bearing on the hard with a horizontal check. However it’s still binding the rudder posts.
    if you simply disconnect your cables and check the independent rudder movement you’ll know for certain. Simultaneously you could link the cable ends apart from the rudders and feel the steering to determine if there is something binding the cables. I doubt that’s the problem. I wager strongly it’s the bearings.
  11. rtrafford
    Vero Beach
    You’re chasing a ghost. The issue is a bad bearing or a bent rudder post. That’s what you need to be focused upon. While you’re at it check the bonding at the rudders and steering assemblies in the laz. Metal boat. Bronze bearing. Electrolysis drives this problem. Causes the bearing shell to swell. Pinches the post (or shaft).
  12. retiredguy
    retiredguy Member
    InTransit
    Will give it a shot!
  13. rtrafford
    Vero Beach
    Add, there is also a thrust bearing at the top of the rudder post with a zirc fitting. This could also be failing or stiff.
  14. rtrafford
    Vero Beach
    Good! Let us know what you find. Mechanical steering is an excellent system if it’s in good shape. No need to replace if that’s the case. When you take the cables loose from the tillers you can tie them together so that you can test the system apart from the rudder tension. That should tell you what you need to know about your steering system. Free, your rudders should rotate with ease while at the dock.
