Click for Westport Click for CL Yachts Click for Abeking Click for Burger Click for YF Listing Service
Steel hull zincs - screws or welding
Discussion in 'Technical Discussion' started by Noa Ramot, Sep 5, 2016.
  1. Noa Ramot
    Noa Ramot New Member
    Tel Aviv
    hello all ,
    I have a 1959' vintage 60ft feadship with steel hull , and I will lift it up to do some below water line maintained and replace zincs,
    As it is set up now the zincs are fixed with bolts to the hull , is welding better ?
    Anyone have good link to read about that ?
    Tnx
  2. Captain Zemo
    Captain Zemo Senior Member
    Midwest
    No, you want to be able to change the zincs in the water. Not have to haul the boat to change a wear item like zincs. As long as the bolts are making good contact, they are fine.
  4. Captain Zemo
    Midwest
    Capt J is 200 +% correct. Keep the bolts setup, and forget about welding Noa Ramot. Just get new zincs and bolt them up.
  5. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    Bolts are way better. Welding is a pain especially if the opposite side of the hull is not easily accessible . Recommend you chase the threads on the studs and use some marine grade never seez and lock washers when you bolt on new zincs. If you are blasting and painting the hull just cut some short pieces of an old hose that fits snug on the studs and that will protect them while you blast and paint.
  6. Beau
    Beau Senior Member
    Beaufort, NC
    I always enjoy learning, I would never have thought welding zinc sacrifice plates to a steel hull would be efficient or even possible
  7. DOCKMASTER
    Ketchikan, Alaska
    I deal with weld-on zincs regularly. They are very typical on commercial, steel hulls. The zincs come with steel tabs to weld to the hull. But as mentioned, bolt-on are much easier provided they are done correctly.
  8. GhostriderIII
    GhostriderIII Senior Member
    Newfoundland
    Welding is a pain. I prefer bolts
