Click for Westport Click for Walker Click for Cross Click for Abeking Click for CL Yachts 99X
Starboard Fuel Gauge
Discussion in 'Carver Yacht' started by CroixToys, Sep 19, 2010.
  1. CroixToys
    CroixToys New Member
    Hastings, MN
    My starboard fuel gauge sort of works. The setup is like this: There is a two way momentary switch. Flip it to port to and the one fuel gauge shows the port tank level, release it goes to center and off, to starboard it shows the starboard tank level. Ok, the port level reads correctly but starboard has the needle bounce back and forth from the actual level to zero constantly.
    This behavior occurs on both the flybridge and the lower helms. Soo...probably the sending unit. S/b pretty straightforwad. I'd like to get an exact match for that sending unit. Do I need to remove to get part number? Not sure how to proceed forward on this.
    This is on a 1983 32' ACMY
    Shouldn't have to, in fact, from 1983 it probably isn't available now. But you need to remove it anyway. So why not now so you know what your looking for.
  3. tommyfmu
    tommyfmu Member
    Freeport, NY
    Before you go removing things, a usual culprit is a loose connection on top of the tank. Check that the nut, bolt, or connector is tight where the send wire is coming off the tank.
  4. CroixToys
    Hastings, MN
    tommfmu is correct
    Went to visit the old girl today and took the advice to just remove the blasted fuel level sending unit. In the process I discovered a rubber gasket that was worn and allowing contact where isolation was needed. I removed it and replaced it with another I had on hand. Then I noticed the wire was not proper tinned marine grade and was pretty filthy. Cleaned the ends and tested. Worked like a champ and I put it all back together. I just needed a good kick in the seat of the pants to get started. THANX!
