Click for Ocean Alexander Click for YF Listing Service Click for Burger Click for Perko Click for Abeking
Source or Mfg for return air grills on 2000 45 Express?
Discussion in 'Cabo Yacht' started by MC02020, Oct 13, 2020.
  1. MC02020
    MC02020 New Member
    Brant Rock & Falmouth, MA
    Wondering if anyone has replaced these?
    The find on mine are showing corrosion and would like to replace if I can track down. They are in a plastic frame, and pop out of an opening about 9" square.
    Could not seem to find any manufacturer name on it. Seems like should be a relatively standard item.
    Figured it could not hurt to ask!
    thanks
    Mike
    Have you contacted Sam's yet?
    Beard Marine A/C in Ft. Lauderdale sells grates that are similar or might even be the same brand. Sam's Marine also in Ft. Lauderdale can source them too.
  4. MC02020
    MC02020 New Member
    Hi, I was able to track down the original manufacturer. They were made by MSI Marine Systems, Inc out of North Carolina.
    http://www.airmsi.com/
    I was able to get in touch with them easily. Unfortunately, they changed their design slightly at some point a number of years ago and no longer make a size that will fit the existing opening. My current opening are 9 1/2" square, the new models would be 10". Over the winter going to look into trimming the openings to make the new ones fit if possible.
