Click for Westport Click for Ocean Alexander Click for Nordhavn Click for Cross Click for Burger
Solar power on a 46.6 convertable
Discussion in 'General Yachting Discussion' started by LenR, Feb 18, 2026 at 12:05 PM.
  1. LenR
    LenR New Member
    Long Island
    What are the thoughts on adding solar to a 46 convertable? Not for full operation just to run the fridg, tv, and a couple lights over night while on an anchor or mooring?
  2. SplashFl
    SplashFl Senior Member
    S. Florida _ Bertram 46
    How do you expect solar to work at night.
  3. LenR
    LenR New Member
    Long Island
    I expect not very well. I should have been more specefic.
    What are the thoughts on adding solar to a 46.6c's electric system with a battery bank, inverter, and selector switch (shore,gen, inv)
    I would start by simply building a battery bank that would run the inverter large enough to handle those items. Lithium batteries are quite small for the amount of AH they hold. It could then be charged during the day by the engines, or generator or a battery charger while on shore power.
  5. Capt Ralph
    No need for a power selector switch. Charger/Inverters are usually in line now days. This way the fridge keeps running automatically if you loose dock power.
    Just maybe a by-pass switch if your concerned with inverter failure/service.
    During daily operation, you will get higher re-charge rates from a gen-set or engine alternator than a solar panel.
    For extended anchoring out with out a fridge (or other heavy loads) running, solar charging is great for bilge pumps and alarms.
    LenR likes this.
  6. LenR
    LenR New Member
    Long Island
    Thats kinda the plan. I'm wondering if anyone has had good or bad experiences doing this? Any mistakes that sound good but just don't work? Any manufactures better than the next? As far as Lithium batteries I think I'd shy away from them due to the chance of an uncontrollable fire. I know they are widely used and are safe but.
  7. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    One approach might be to add the battery bank and inverter system first... then use it... evaluate... decide whether adding solar to that would be worth the effort.
    Saying "lithium" as a general class is slightly different from saying LiFePO4 (aka LFP). Latter are inside the whole lithium class, but a different lithium chemistry from the small batteries in laptops or hand tools or whatever... and reading suggests there are no known fire events caused by LFPs. None. Zip. Nada.
    -Chris
    leeky and d_meister like this.
  8. SplashFl
    Don't know if you follow this guy but in the link I'll post he installed what appeared to me a great battery set up despite having 2 generators.
  9. LenR
    LenR New Member
    Long Island
    Great video and a lot of information. A much bigger system than I'm looking to do but I'll definitely look into the manufacturer.
  10. LenR
    LenR New Member
    Long Island
    The only reason I'm not a fan of Lithium is I've seen FD trying to put out lithium fires. It turns into a containment till it burns out not putting the fire out.
  11. SplashFl
    Just had a new generator installed on mine; but I never do overnight anchor outs.
  12. ranger58sb
    Chesapeake Bay, USA
    Understand, but "lithium" is a larger playing field than the smaller LFP subset. Ask your FD guys "which lithium" they were dealing with. Or try to find a documented case of LFP-caused fire. (I suspect there may have been boat fires where LFPs were installed, but the fire was caused by something else. No first-hand info on that, though.)
    -Chris
