Click for Northern Lights Click for YF Listing Service Click for Walker Click for Westport Click for Abeking
SMXir Cruiseair thermostats junk
Discussion in 'Technical Discussion' started by CSkipR, Oct 12, 2014.
  1. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    Over the past 5 years I have to replace the two thermostats twice. What is it with these thermostats? Up/down temp button won't go both ways or cannot get to program menu by pressing off/set. Does anyone have this issue? IMO seems Dometic could build a better thermostat.
    Big SMX panel or the lil SMX / IR with a cover door? The big panel was junk, lil panel (with door) lasted about the same as the PassPort panels did.
  3. Pascal
    Make sure it s not a wiring issue. I ve had that happened a couple of times, either the connector in the back of th panel or a coupler for those phone style connectors hidden in the wiring to the compressors in the ER that had corrosion.
    Panels themselves have been pretty good
    Now, if there was a way to disable the IR function so that TV remotes woudlnt not switch units from cool to heat!
  4. Caltexflanc
    Caltexflanc Senior Member
    North Carolina
