Click for Glendinning Click for YF Listing Service Click for Abeking Click for Cross Click for CL Yachts 99X
Slow responding autopilot
Discussion in 'Technical Discussion' started by Danvilletim, Jul 13, 2015.
  1. Danvilletim
    Danvilletim Senior Member
    isleton, ca
    Yesterday I noticed the auto pilot ( both primary and backup) were responding much slower than normal. Any ideas on where to begin to look?
  2. TeKeela
    TeKeela Member
    NC & Puerto Rico
    Define "responding"
    And are you referring to using it in Nav mode or Auto?
    Do you use the same compass for both primary and backup?
    Do you have two pumps plumbed in or one?
  3. Danvilletim
    isleton, ca
    Two pumps. The boat adjusts very slowly to small course changes in auto mode. I think there are two compass installed below.
    Could it be the power steering?
  4. TeKeela
    TeKeela Member
    NC & Puerto Rico
    When you are testing, one or the other pilot pumps are valved off?
    Yes I would think it could be power steering but it could also be air in the lines.
    Anything sitting on the ram in the lazzerette? A big fender? As in it is slow to respond with steering input too? Or just pilot.
    Robertson on that thing, yes?
    What brand of autopilot? Check the steering system and make sure their is fluid and pressure first. Then go into the menu and try turning up the response level. If it's simrad, if you hit auto twice it will go into hi mode and will say it on the screen and should respond quicker.
  6. Danvilletim
    isleton, ca
    Great. One is simrad and one is comnav. I'm going to check fluid levels first. These does seem to be an air leak where you charge the system. It will hold for a day or two. Any tips on stoping air leak.
