Click for Northern Lights Click for YF Listing Service Click for Ocean Alexander Click for Walker Click for Glendinning
Sling Box
Discussion in 'Technical Discussion' started by captbluewater, Jan 22, 2011.
  1. captbluewater
    captbluewater New Member
    Los Suenos
    Has anyone used and had any success using Sling Box on Yachts traveling the Bahamas and Carribean. This Box hooks up to your TV at home and sends TV signal from your home by internet to your computer . Thanks
  2. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    Just used one here on board in Costa Rica. Worked fine.
  3. captbluewater
    Los Suenos
    Thanks Bill I recently left Costa Rica after 8 yrs and have a new job on a 77 Hatteras that does not have a Sat TV and was wondering if this would be a cheaper opption as long as we have internet access. Capt Ron
    The problem I've found in most places in the Bahamas and a good amount of places in the Carribbean is that you don't have good enough internet to run a program like that. Either the bandwidth is too slow, or the internet cuts in and out. I have that issue often with Skype, which uses a lot less bandwidth then tv......but I don't see why not, if you have good enough internet where you're at.
