Click for JetForums Click for YF Listing Service Click for Glendinning Click for Mulder Click for Burger
Sirena 64 - fresh water issue
Discussion in 'General Yachting Discussion' started by John foye, Sep 7, 2021.
  1. John foye
    John foye New Member
    Ft Myers fl
    I have a new 64 Sirena. The fresh water system onboard produces an irritating gas that bubbles up in the water from every tap. I have followed all sirenas instructions for flushing the tank and lines with very limited results. Any ideas from Sirena owners
  2. Pascal
    When you say gas, do you mean air or is there a smell?
    what kind of water pump do you have ?
    If air gets sucked in the pump, it has to be between the tank and the pump. Check the strainer before the pump to make sure the gasket or o ring is on correctly
  3. German Yachting
    German Yachting Senior Member
    West Coast
    Is it a foam? If so, the hot and cold water lines might still need to be flushed more to get the antifreeze type stuff they add in there completely flushed out.
  4. John foye
    Ft Myers fl
    It foams up and leaves a chemical odor that has a chemical smell that actually leaves a acid like feeling in the nostrils and throat
    Where are you getting the water from that you're filling the tank? Is it at a marina with CITY water, or are you filling the tank with well water? Are you using a hose rated for DRINKING water and flushing the hose out for a minute or two before filling the water tank with it?
  6. John foye
    Ft Myers fl
    City water, drinking water certified hose, system has been flushed with manufacturers suggested flush. Still has acrid gas smell and throat irritation
    How many times have you flushed the tank out? I would probably think you'd have to do it 6-10 times. What material is the tank made from?
  8. Pascal
    Yeah empty and refill. Empty and refill. As many time as necessary. How old the boat ?
  9. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    You said it is a "NEW" boat. Where's your dealer? They should be helping you with this
    Rerm likes this.
  10. German Yachting
    West Coast
    Sounds like you just need to flush all your hot and cold water lines throughout the boat until it is gone. Can take quite a few tanks as others have stated for it to go away.
  11. mapism
    mapism Senior Member
    Sardinia
    That sounds VERY worrying, particularly in a new boat.
    Whatever the reason, I would involve the dealer as Dockmaster suggested, even before attempting repeated flushes or any other DIY fixes. And with a written notification.
  12. John foye
    Ft Myers fl
    O
    i have notified the dealer many times and they say flush flush flush. It’s a 400 gal tank. I have emptied it at least 6 or 7 times then after a couple days the same issue returns. The dealer is Sirena Yachts Ft Lauderdale Fl
  13. TahoeJohn
    TahoeJohn Member
    Tahoe VIsta
    Is there a water filter somewhere that serves the whole boat's freshwater system? I had a bad carbon filter on my galley sink that added a lot of bubbles and a definite taste. Replacing it solved the issue.
  14. olderboater
    Who does provide the service for Sirena? What yard do they use?
  15. Capt J
    Is the tank fiberglass? It sounds like it is and the epoxy/paint/gelcoat etc. they coated the inside with wasn't mixed properly and is off-gassing. Call the dealer and tell them to get somebody to the boat to fix it.
