Click for CL Yachts 99X Click for Northern Lights Click for Burger Click for Westport Click for Westport
Sick Cat 3160's
Discussion in 'Engines' started by cptmik, Mar 22, 2014.
  1. cptmik
    cptmik New Member
    Melbourne
    Hello All,
    I have recently purchased a 48ft flybridge cruiser with a pair of 3160 cats. She is from 1978 with only 800 odd hours on the engines. Both engines are leaking fuel from the fuel pumps, which I am told is an internal O-ring. My problem is I have been given an estimate of up to 6k each to rebuild them. Does anyone know of a good source of cat 3160 parts.
    Mik
  2. SeaEric
    SeaEric YF Historian
    out on the dock
    Around 2 years ago I had a pair of leaking fuel pumps rebuilt on a pair of 3208's which are very similar engines. Access to those pumps to remove them is, AFAIK not easy. There was a fair amount of labor in the R & R. It seems to me that the total bill was around $2,500. total for both. I can pull the file and tell you for sure. I'd get a second quote on that one.
  3. cptmik
    cptmik New Member
    Melbourne
    Thanks Eric,
    I was expecting something like that but the fuel pumps are the big difference, 3208 is a V shaped and 3160 are straight.
  4. SeaEric
    out on the dock
    3160 is a v8 engine. Perhaps you're referring to a 3116 which is indeed a straight 6.
  5. dsharp
    dsharp Senior Member
    lake jackson, tx
    He's talking about the injector pump. The 3160 used a straigh injector pump and the 3208 has a v shaped pump. It's not that hard to remove the injector pump. You have to pay attention to the timing.
  6. cptmik
    cptmik New Member
    Melbourne
    I was referring to the shape of the fuel pump
  7. dsharp
    lake jackson, tx
    The fuel pump is on the right hand side of the block. The "injector" pump is on the top of the engine in the lifter valley. You need to make sure it's not leaking fuel into the oil pan. Why do you think the engines need rebuilt?
    Probably from fuel leaking into the oil pan and washing the bearings, if I had to guess.
  9. cptmik
    cptmik New Member
    Melbourne
    The engines are fine, its just the injector pumps that need rebuilding
