Click for Westport Click for Perko Click for Mulder Click for Ocean Alexander Click for Glendinning
Shore Water Connection - 2001 - 52 SS
Discussion in 'Ocean Yacht' started by Controlled Chaos, Sep 30, 2017.
  1. Controlled Chaos
    Controlled Chaos New Member
    Rancho Palos Verdes, CA
    My 2001 - 52SS does not have shore water connection, don’t understand why? It’s a pain in the butt to keep filling the (150gal) tank. Prior to putting the boat on a ship to MX. My son and I spent about 1.5 month living on the boat waiting for the ship to show up at Port Everglades. Also had brief encounter with Irma, luckily we got spared with no damages and very little surge. Sorry for the topic side track...lol
    Can you guys tell me?
    a. If you have shore water connection.
    b. Where is it located/installed on the cockpit area?
    c. Is the water pipe run all the way to service side of pump?
    d. Any pictures, would be truly appreciated.
    Thank you all and have a pleasant weekend,
    Carlos
  2. rpontual
    rpontual Member
    Miami Beach, FL
    I have a different boat. It has shore water connection and I am very familiar with how it is connected. The external outlet, which is suitable to connect a regular hose, connects to a check-valve. The output of the check-valve connects to a pressurized cold water tube (blue in my boat). The tube is the same that brings water to the transom shower.
    In my boat there is no need to do anything one the shore water is connected. Because the shore water has higher pressure than the pump, once shore water is connected the pump does not come in and all water consumed comes from shore.
    a. I have, b. located at the transom close to power area, c. water pipe short to a pipe in the engine room on the pressured side of the pump, d. pictures may not be relevant to you because my boat is different (but I can take some).
  3. Controlled Chaos
    Thank you, I got the idea...just need the OY folks to shine in...
  4. Just Cruisin
    Just Cruisin Member
    Detroit, MI
    Carlos, I might be able to help. Just recently purchased(last April) a 1994 53 Ocean Super Sport and had the same question.
    You might have two water outlets in the cockpit as I do. One is for the raw water wash down and one runs off of the boat fresh water system.
    "I was told" that you can connect shore water to the boat fresh water outlet. **You will have to make a hose or connection with two female ends.** One for the hose and one for the outlet. You can then hook shore water up to the boat fresh water system.
    I have not tried it yet but will. Also, not sure but guessing that you will have to turn off your fresh water pump if you are connected to shore water.
    I can not talk to the plumbing as I have not traced the system back.
    You might try calling Ocean Yachts - 609-965-4616. I did speak to a Bob Hawkins who seemed to have some knowledge of the boats.
    Good luck and enjoy your Ocean as I do mine.
  5. Just Cruisin
    Just Cruisin Member
    Detroit, MI
    From my owners manual - The shore water system starts with the sillcock hose connection in the cockpit. The water flows to the yacht water distribution system. The fresh water tank can be filled from the dockside hose.
    There is a 12 volt breaker for the fresh water fill. Activating the switch triggers a "Murphy Valve" whick will allow water from the dock to fill the fresh water tank. When water flows from the water tank vent, turn off the breaker.
    With the breaker off, I think it backfeeds the freshwater system and with the pump shut off you can use it as dockwise water.
  7. bobhorn
    bobhorn Member
    Kemah, TX
    On boats we have had there was a check valve in line with the pump to keep from backflowing through the pump.
  8. Pascal
    Personally I never connect to shore water. Never. Blow a hose or fixtures and you'd better hope your bilge pumps don't burn up. Sure, you can turn it off when you leave the boat but sooner or later you ll forget
    I normally leave the water hose in the filler when at home dock and just refill as needed.
  9. bobhorn
    bobhorn Member
    Kemah, TX
    We have always not only turned off the spigot, but also disconnected the hose whenever we left the boat. Coming off the boat we walked right past it so it was hard to forget.
  10. Prospective
    Prospective Senior Member
    New England
    On my 43' this is the answer as well. I have never done it but Ocean didn't install dock side water on my model. Not sure about others. One word of caution in addition to the others is I would put a pressure regulator on between the spigot and hose. I believe this is standard on an installed city water hook-up. Dock side/city water pressure could be much higher than what you get via your onboard pump and could blow out your plumbing if you're not careful.
  11. bobhorn
    bobhorn Member
    Kemah, TX
    The fittings you can by for the boat end come with a pressure regulator built in.
  12. Controlled Chaos
    JC,
    Thanks for the input. Your idea was my first thought. However, the fresh water wash down has a check valve that wont let water in the system. I was actually surprised that a cv was installed.
    I will give Bob a call and see what are my options...if I have to run a line all the way to pump service side, its going to be a RPA.
  13. Controlled Chaos
    I have a check valve on the fresh water wash down...planning to see if I can locate the cv then T-off...bought all the necessary fittings including pressure regulator. Can wait till the boat is finally in CA waters. The project list keeps growing by the day. lol
    Thank you,
    Carlos
  14. Controlled Chaos
    Not crazy about the idea of a hose in a partially open water inlet, unless there is a device that acts as plug with hose!
    Thank you,
    Carlos
  15. Controlled Chaos
    You are correct, but the ones I've seen are typically designed for RVs. I'm looking for something more streamed line with regulator and SS. I'm thinking of taking a marine ss water inlet and installing a pressure valve opposite side.
  16. Controlled Chaos
  17. Controlled Chaos
    Do you have a diagram of the system that you can email me...csarria@att.net
  18. Controlled Chaos
    check valve wont let me.
  19. bobhorn
    bobhorn Member
    Kemah, TX
    West Marine, Defender and others have them for boats. Not sure about the base material but they are finished in chrome.
  20. Controlled Chaos
    I found a bright SS water inlet in Amazon...going to also add pressure and check valve.
