Click for Burger Click for Burger Click for Delta Click for YF Listing Service Click for CL Yachts 99X
shift cable problems
Discussion in 'Technical Discussion' started by JonMcg, May 5, 2016.
  1. JonMcg
    JonMcg New Member
    my engine dies sometimes when i move from reverse to neutral. the nut on the control cable is loose, how do i adjust it to stop the problem?
  2. Lepke
    Lepke Member
    Knowing engine and trans would help. Problem is not necessarily in the cable. In a diesel the problem could be the governor not set correctly or the stop linkage going to the injector pump.
    What engine do you have? What type/brand of cable. Usually if a control cable has an adjustment nut on it, it has two nuts. If it's a gas inboard, they usually have an adjustment on the engine or engine distributor/coil that retards timing when the motor is shifted and that probably needs adjustment.
