Click for Mulder Click for Glendinning Click for YF Listing Service Click for Abeking Click for Westport
Shark Bite Line Cutters
Discussion in 'General Yachting Discussion' started by Boston whaler, Feb 16, 2019.
  1. Boston whaler
    Boston whaler New Member
    Charleston, S.C.
    hauling out Monday and just came across AB Marine's "Shark Bite" prop shaft line cutters. Does anyone have experience with these? Pros and cons vs. Spurr's line cutters?
    Any quick input would be much appreciated.
    Our diver tells us; when any cutter system does not work or still fowls, it's very (VERY) expensive to clear.
    Seems he likes his fingers.
    We don't have spurs and our gear eats crab pots well by themselves.
    Our diver is under our boat at least once a month. The remaining pot lines he throws up on the dock.
    Now, we have an old boat with 32" wheels and 3" shafts.
    Your results may vary..
  3. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    Why do you have a diver under your boat once a month? that seems like a lot to me . Why ,CR, Why? Lol... o_O
  4. Boston whaler
    Charleston, S.C.
    Capt Ralph: thanks for your input. Mine is 1971 vintage with 2 1/2" shafts and 4 blade 30"x 30" wheels. Might do the trick with pot warps , but at 66 don't relish diving in cold water to try and clear a wrapped line. Hoping to spend time in Maine and definitely the Chesapeake, pots thicker than boats, but certainly understand your diver's point. The shark bites look like a serrated circular saw and Iwouldn't want my fingers anywhere near them.
  5. Capt Ralph
    The sediment in these waters is unreal. Bottom covered about every month and the paint is worthless then.
    Diver just has to dust / wipe the bottom to reveal fresh bottom paint.
    My zincs last about 6-7 months here at Huckins. Use to last longer till these relics moved in around me.
    When the water temp is way up, a shag carpet can grow on the hulls almost over night.
    Soon will be moving further up river and retiring again. Leaving these sediment and poo rich waters.
  6. Oscarvan
    Oscarvan Senior Member
    Chesapeake Bay
    There are chainmail like gloves chefs use when they get tired of cutting themselves. I would think they would be perfect for clearing gear with cutters.
  7. Capt Ralph
    Probably works well when you can see what your doing. In these waters, it's by feel and remembering what it looks like. Zero vis on a good day under these boats.
    Divers here take pictures of customers hull bottoms (when hauled) to help recall (when needed) what is under there & where strainers & zincs are.
    I have a picture libary of all bottoms (of boats) that we have ever serviced.
    Comes in hand for Josie's surveyors, electronic techs & lift operators.
    Also, what kind of cutter if equipped. Some require service.
  8. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    We've always fitted the Spurs type cutter rather than the circular-saw design. The scissor action seems to work better.
    One captain told me of picking up a pot line that perfectly wound itself, like a fishing reel, up along his shaft and not only started to pull the shaft out but also cracked the bell-housing as it was getting dragged out. He got towed back the 11 miles in a F9.
  9. cleanslate
    Cherry Hill, NJ
    Wow! I did not know that. That stinks. What's around you, some old FlairForm Fyers? Well when you get up to DeLand things will be better including the fishing with golden shiners from your Ranger. Lol!
  10. Capt Ralph
    Surrounded by old FairForm Dock-Queens.
    Next Homestead; Satsuma FL.
    No speed limits, fast or slow.
    Converting the work boats to fish boats.
    Going to convert the tow bits to gator bits.
    Lots of crab pots down this way. I'm sure I'll wrap up a few of them.
    One of Josie's divers is in StAug. He will start checking our bottom and start a new schedule with the new river water.
  11. Pascal
    I ve tried spurs but it seemed that very few months they were shedding an (expensive) part even though they were installed by spurs (or one of their certified installer)
    Gave up on them. Once in a while the diver pulls a piece of line or we do when in the Bahamas
    Single piece cutters may not work as well but simpler.
    And yes anywhere in warm waters (Florida) you need a diver to clean the bottom and running gear every month
  12. revluc
    revluc Member
    Gulf Coast
    I have thought about "cutters" because I accept it isn't a matter of IF but WHEN I was actually run over a crab pot. This thread is leaving me undecided again...
    As for the diver, yes it FL we have one under the boat once a month .
  13. motoryachtlover
    motoryachtlover Senior Member
    smithfield, VA
    I used to have spurs but removed them when something came undone and one side was loose on the shaft. I got rid of them a couple of years ago and no regrets as of yet.
  14. cleanslate
    Cherry Hill, NJ
    Sounds good. Watch out for the SeaCows! What kind of crab on the St. Johns? Blue crab pots?
  15. cleanslate
    Cherry Hill, NJ
    So it's best to go with an inexpensive bottom paint , since it seems it's for aesthetics only? Since diver is keeping things clean.
  16. cleanslate
    Cherry Hill, NJ
    Actually crabbing on the Bay is done a lot by Trotlines where you have only two buoys marking the trot trap line which is on the bottom the buoys are spread way apart with pots in between , which cuts down on the crabbers loosing pots to ''us''. So not as many pots to avoid. Crab markers on the bay tend to be set a set depths given the time of year so try to set your course out of that depth zone.. usually 15/20 foot area.
    I've never used cutters etc. on my boats. I never got a pot around my prop or shaft. I also have never had an automatic pilot on my boats, just my sharp eyes and hold my conversations while looking forward most times...rude I know, ready to dodge pot makers and Delaware river debris..that one is an acquired skill plus low speed.;)
  17. Oscarvan
    Chesapeake Bay
    And they will often follow the contour. When there's lines or fields of pots they're not supposed to block harbor entrances and they are supposed to stay out of the navigation channels but some of the watermen will trap them and then I think it's on them. It's always a back and forth. One of the reasons why for me day operation is preferred especially into unknown waters outside of channels, and night operation will be slow unless you really know the area.
  18. Capt Ralph
    I have a recipe for manite chili around here somewhere.
    Yep, blue crabs.
  19. Capt Ralph
  20. Oscarvan
    Chesapeake Bay
    Suuuure. You put some crap on there and watch your diver charge you double because now he's scraping instead of wiping/brushing.
