Click for Perko Click for YF Listing Service Click for Ocean Alexander Click for JetForums Click for Cross
Shaft zincs keep falling off
Discussion in 'Props, Shafts & Seals' started by incoming, Oct 12, 2025.
  1. incoming
    incoming Active Member
    Cocoa Beach, FL
    I’ve been struggling with keeping my shaft zincs in place. Never had the problem with other boats. I’ve tried the 4 bolt and the 2 bolt zincs and keep having the same problem - they slide down the shafts after a few hours of running, making me worried about damage to my cutless bearings, then eventually fall off. Anyone have a solution for this? I believe my shafts are 2.5”.
    Installed on land or by a diver.
    Shaft polished clean before the new install or just where the old zinc was??
    With a BFH*, driving the contact brass button in and re-tightening?
    Quality zincs?
    Checking the screws every cleaning?
    * Big Freaking Hammer
  3. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    As CR mentioned, you have to smack them pretty good with a hammer to make sure they seat well. Then tighten the bolts and smack again then a final tighten of the bolts. A drop or two of loctite never hurts if done with enough time for it to dry.
  4. incoming
    Cocoa Beach, FL
    These have all been done by a diver, or me holding my breath in the middle of a trip when i realize they are gone or have come loose.
    So is it not really possible to have them done right underwater?
  5. Capt Ralph
    Why not?
    Hammers work under water. ♪♫ If I had a hammer ♫♪
    But a breath hold dive probably will not make it.
    But, it takes a quality zinc also.
    Your looking for those brass buttons on the inside, to make that electrical connection and get a bite on the clean shaft.
  6. incoming
    Cocoa Beach, FL
    Sounds like I should try a new diver
  7. Capt Ralph
    Or ask your diver to update his installation and materials.
