Click for Glendinning Click for YF Listing Service Click for Burger Click for Mulder Click for Westport
Shaft seal lubrication
Discussion in 'Props, Shafts & Seals' started by CSkipR, Jan 1, 2017.
  1. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    Been slightly over a year since new shaft seals were installed on the shafts. Want to check the water flow to seals to be sure it is flowing well. Believe last seals went bad because of build up of salt in the elbows and decreased or stopped water flow. Obviously the engines need to be running but the boat doesn't have to be moving does it?
    No, just have the engines running.
  3. CSkipR
    CSkipR Member
    I really like the shaft seals Cabo used. They were from a company out of CA. I forget the name of the company but they had bronze bodies and were high quality with a very low failure rate. The seals do just wear out from age/use/and time. I wonder why no other builder ended up using them that I know of.
  5. CSkipR
    CSkipR Member
    Yes they are very heavy duty Blue Water by Chatfield Marine. Still have them if anyone has a need. I removed them and installed Tides because they have the ability to replace the seal while in the water.
