Click for Ocean Alexander Click for Westport Click for Glendinning Click for Burger Click for Abeking
Shaft seal leak in the keys - struck a bamboo pole
Discussion in 'Props, Shafts & Seals' started by incoming, May 30, 2023.
  1. incoming
    incoming Active Member
    Cocoa Beach, FL
    I struck a partially submerged bamboo pole on the way in from fishing yesterday and my port shaft seal is leaking now.
    Besides the leak, I can't see any signs of damage. Although the pole was large (~10' long, 5" diameter) it was pretty lightweight being hollow bamboo.
    I have one spare seal left on that side. Question is - since the leak was caused by me hitting something, is it rolling the dice to replace it with my last seal or do I really need to get the alignment checked or even get the boat hauled to check struts, etc?
    In other words, is it somewhat common for a debris strike to cause a shaft seal leak, or is it far more likely that the strike knocked something out of alignment and the new seal will just start leaking once I replace it? Since it's my last one, I really don't want to have it start leaking on my way back north without a spare seal.
    This is a 2 3/4" shaft on a viking SF
  2. Pascal
    Any vibration, wobble in the shaft etc ? At what speed did you hit ? I don’t see how the seal could start leaking unless something got bent.
  3. rtrafford
    rtrafford Senior Member
    Vero Beach
    Agreed, that's where my mind went, too.
  4. incoming
    Cocoa Beach, FL
    I hit the pole at about 15 kts. I was just climbing up on plane. At the time, I really didn’t think it had hit the prop because I dove on the hull and saw a scratch in the bottom paint up on toward the bow, right where I thought I hit it.
    no vibrations, no loss in speed at rpm, no visible (underwater) damage to anything I could see besides the scratch in the bottom paint.
    I had a local yard take a look. Note I just had the cutlass bearings and shaft seals replaced about a month ago. Here was their take:
    -the hose over the shaft log was the wrong kind - too stiff. They said the correct installation would be a silicone hose with a lot more give to it. The stiff hose would cause the seal to wear quickly.
    -the shaft has a number of burrs and imperfections. These should have been filed down and sanded smooth when the new seals were installed. Also, the new seals should have been installed with a “red hat” looking thing that slides under the seal when moving it around on the shaft. It doesn’t appear any of this was done
    -they think, most likely, the seal was damaged when installed, and the spare seal is suspect for the same reason, and/or the stuff hose accelerated failure
    -hitting the bamboo may or may not have been the proverbial straw that broke the camels back, with the vibration from the strike translated through the stiff hose to the seal. Or, it was just coincidence and I noticed the leak because I was looking for it.
    -if I simply replaced the seal with the spare, as I originally planned, it may have leaked the same or worse and I’d be out of spares
    suggested course of action is to pull both shafts back, re-do the shaft log hose and put on new seals and new spares.
    very frustrating
  5. Pascal
    I would get a second opinion from the seal manufacturer about the hose type.
    how much is it leaking?
    MBevins likes this.
  6. incoming
    Cocoa Beach, FL
    It leaks very little to none when stationary. It was dripping at first but it stopped all together overnight.
    At idle speed, it leaks a noticeable but small stream at the bottom of the seal.
    At cruise, it’s more of a spray than a stream, throwing water around enough to wet everything between the two stringers the shaft runs between.
    I could try calling tides. Good suggestion. The guy who installed them is gonna be very defensive when I tell him what happened, so it’s probably best to have the best data possible.
  7. Donzi 54
    Donzi 54 Member
    Point Pleasant, NJ & Morehead City, NC
    Tide Seals use a silicone rubber articulating hose. Also confirm that you have good water flow to those seals.
  8. incoming
    Cocoa Beach, FL
    I talked to tides. They said the only correct installation is with their hose. The black hose installed by my tech was definitely wrong
    They also said the seal housing was likely an original install and well past it's service life. They recommend complete replacement of the whole system.
