Click for Northern Lights Click for Walker Click for YF Listing Service Click for Mulder Click for Cross
Sedan Bridge Sliding Door Trucks
Discussion in 'Sea Ray Yacht' started by Thisisit, May 19, 2022.
  1. Thisisit
    Thisisit Member
    Midland, Ontario, Canada
    Has anybody replaced the lower trucks on the glass sliding cockpit door? Ours sound and feel like they need replacing. I can't see the type of trucks needed even with the door removed. The fuzzy dust frills obscure everything.
    FPMarine has trucks available but I don't know which to order. I have loosened the screws but the trucks don't drop out and like I said, the frills make it impossible to see what's going on up inside.
    I am at the point where I will attempt to disassemble the door frame at the bottom though it doesn't look possible. Just wondering if I'll be able to get the genie back in the bottle once I pull the door apart.
  2. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    If you haven't already...
    Look in your Parts Manual for hints.... although the door might be listed only as an assembly in the Parts Manual
    But if that doesn't help, call/email Sea Ray; they might be able to add info. Contact info in their "For Owners" section...
    -Chris
  3. Thisisit
    Thisisit Member
    Thanks Chris, I will call them. Hopefully they will have tips on the replacemnet procedure as well as the part number.
    In the meantime, I will check the manual one more time.
