Click for Westport Click for YF Listing Service Click for Delta Click for CL Yachts 99X Click for Abeking
SEA-FIRE FM-200 System's Issue
Discussion in 'Technical Discussion' started by JulieYang, Aug 11, 2015.
  1. JulieYang
    JulieYang New Member
    China
    I got an issue of SEA-FIRE FM-200 system on yacht, please help.
    Every time i put the SEA-FIRE system's power on , after two hours the alarm of saloon and crew and main helm will ring but we did not get any fire on yacht, and the accommodation light on SEA-FIRE panel will light.
  2. K1W1
    Is the system being triggered by a detector in the loop somewhere or is there a voltage problem?
  3. Bamboo
    Bamboo Senior Member
    Palm Beach, FL
    Is this a single bottle in the engine room? If so it's "armed" all the time in that if there fire in the ER then the bottle will discharge. It has a tiny glass vial which breaks (due to heat) and the bottle discharges. The vial can also be broken thus discharging the bottle with the manual remote cable. You should have a manual over-ride switch/unit activation alarm near the helm to restart the engines as they will shut down upon discharge. If you have alarms for the differing areas of the vessel then look further into K1w1's suggestions.
