Click for Mulder Click for Glendinning Click for Burger Click for Westport Click for Abeking
Saddle tank usage
Discussion in 'Luhrs Yacht' started by Joe McKairnes, Oct 2, 2020.
  1. Joe McKairnes
    Joe McKairnes Senior Member
    lacey twp NJ
    Luhrs 40 open has 2 saddle tanks. Do you guys leave the shut off Vales open, so you can transfer them at will, or shut, then need to switch them when needed?
  2. CaptainChase
    CaptainChase Member
    Seabrook, TX
    I leave mine open. Mains and gen run off main tank and when I get low on that tank I transfer both saddle tanks back to main tank. Just what works for us!
  3. NYCAP123
    If you're going to be running with a beam sea all day, such as when you're running down a coast, you might drain the side opposite the waves first so she leans into it, but otherwise leave them all open
    Generally I leave the valve all open. Always transfer the saddles empty before fueling......that way at least the saddles have 98% fresh fuel in them......
  5. Joe McKairnes
    lacey twp NJ
    Thank you folks. New to her. Picked her up in NC and running to NJ. At the Chesapeake at the moment!
  6. CaptainChase
    CaptainChase Member
    Seabrook, TX
    More than anything, enjoy your trip and learn the boat! Safe travels
