Click for Northern Lights Click for Furuno Click for Abeking Click for Mulder Click for Delta
rusty steel hulls
Discussion in 'Technical Discussion' started by stiletto28, Oct 25, 2010.
  1. stiletto28
    stiletto28 New Member
    Eagle Harbor, WI - Hayling Island, UK
    Hello All,
    Right, so we've just bought a 40' steel schooner. There are some rust issues on the exterior of the hull that we're going to have sandblasted, but what about the inside? There are some spot issues within the bilge, etc., and we're trying to decide as to the best method for rust removal...disc grinder? chemical? sandblast? Any thoughts on this would be useful, as we can't seem to agree on the best method....thanks!!
  2. travler
    travler Senior Member
    roche harbor wa
    i would invest in a couple of good needle guns and a lot of labor
  3. NYCAP123
  4. stiletto28
    Thanks for the input guys. We have had a survey done, and she's pretty solid throughout, ranging from 6-8mm for the majority and almost 16mm in the keel and rudder. I'll have a browse through that link, thanks again!
  5. m2m
    m2m Senior Member
    newport ri
    If the rust isn't to bad Tavler is right, invest in a needle gun and a wire brush. Clean the areas as best you can and follow with Ospho or something like Corroseal which converts the rust and seals the metal from further corrosion. This can be followed up with an epoxy paint system. Years ago I did this on a Army Corps Engineers boat in a machinery space and I saw the boat several years later and it still looked good.
  6. sunshine08720
    sunshine08720 New Member
    Bay Head now Hertford, N.C.
    Interior coating
    You might want to take a look at C . I. M. (Chevrons Industrial Membrane) a liquid rubber membrane for the interior. Properly applied, it's there forever.
  7. Loren Schweizer
    Coral Gables/Ft. Laud., FL
    Stiletto, immediately after sandblasting/needle gun/whatever, down to what they call "white metal"....add a coat or two of zinc primer.
  8. Marmot
    Before doing anything of the sort I would determine what coating system I want to use and follow the procedures prescribed by the manufacturer of that coating.
    Adding a layer of something that may or may not be compatible just leads to a duplication of work and expense, or a failure of the coating system in the near future.
  9. sunshine08720
    steel hull
    For forty years I (my company) sandblasted and painted steel water tanks. We came across the Chevron product many years ago with a great degree of success, again give proper surface preparation and application. see
    www.cimindustries.com
  10. travler
    roche harbor wa
    a lot of good advice here as an owner of a steel boat for the last 40 years are so i would evaluate wich coating system i was going to use (as marmot sujested) and go for there we have used the ppg amerlock system for a few years now and have had good luck , there are other systems that are quite good i would evaluate wich would be best for your need,s
    just a thought travler
  11. Loren Schweizer
    Marmot, unlike many here who 'shoot from the lip', I have personal experience in building and maintaining A36 steel-plated expedition vessels. As advised by Joe Purtell of U.S. Paints/Azko Nobel, inorganic zinc primer on white metal finish is/was the default and initial coating in the process, followed by brand name (Interlux or Awlgrip) epoxy primers, then layers of fairing material and finishing with a brand name linear polyurethane.
    At least that's how it was done, per the experts. Did some other coating--incompatible with zinc-- come on-market in the past couple of years that puts egg on my face?
    I am by no means an expert and would hope that one weighs in on this.
  12. Marmot
    Not that I know of. It is just good practice to select a coating system and prepare in accordance with that manufacturer's instructions before using any third party product that will underly that system.
    No offense intended, it is just that there are many "zinc primers" on the market. Some of which may or may not use a carrier or solvent compatible with all coating systems.
    Given the cost of hull preparation and application of a marine coating system it is simply a prudent approach to carefully plan such a project.
  13. Henning
    Henning Senior Member
    Ft Lauderdale FL
    Inside, especially in an engineroom, I prefer CO2 blasting.
  14. m2m
    m2m Senior Member
    newport ri
    In another life I painted a lot of steel boats and the zinc primers were compatible with any epoxy topcoat. But I agree with Marmot it is unwise to mix different manufacturers products it's set up for failure or beter yet if there is a warranty issue your out of luck.
  15. stiletto28
    thanks for the input
    Lots of great input here guys. We've ruled out sandblasting the interior, as it would be an epic mess to deal with.
    However there is one bit that I'm not familiar with...CO2 blasting? I don't know much about steel boats as it is, so a bit of elaboration on this method would be awesome...We're heading down to the boat this weekend to fully assess how much rust-removal needs to be done on the interior, so more to follow.....cheers and many thanks
  16. Marmot
    CO2 blasting uses crushed dry ice for media. It has its place but not too sure if it is the best thing to use in the hull interior. It is expensive, noisy, and requires extra ventilation so as not to asphixiate everyone in the interior. The rust and paint chips still need to be cleaned up so the work is no less. The only place I have found it to be really useful is in an area where you simply can't afford to have any blasting media residue, but don't have access to the areas behind or under the work, such as removing hard packed soot from the fin tubes of a boiler economizer. But I don't think you have one of those on your boat.
    There are vacuum nozzles which reduce the junk to almost nil so cleanup and "overspray" are no longer an issue, much less an "epic mess." If the thought of highly abrasive grit bothers you, there is soda blasting. It uses plain old ordinary baking soda that is about as "green" as it gets and won't come back to haunt you in the future. Combine that with a vacuum nozzle and life is good.
  17. frankie252
    frankie252 New Member
    New Bern, NC
    Surface Prep
    Dry ice is a slow process but very effective. You can also use High pressure liquid blasting. Generally runs 40,000 psi water pressure to blast clean any rust there. However you don't get the original Mil profile that was once there and may need mechanical or abrasive blasting to achieve a good profile for your primer due to rust eating away the profile. As far as a primer on A36,56, or 105 steels. I kinda move away from Zinc primers. Due to galvanic action the zinc erodes away protecting the carbon steel leaving voids,blisters between the primer and top coat. This is why you have zinc bars through out the hull. If you have cathodic protection incorporated into you electrical system it works fairly well in this application however. If you use a organic or inorganic zinc use an epoxy equal to it that will allow even erosion and wear so you can tell when a problem appears. Zinc paints usually need a system to keep the solids stirred while painting for even application as well. An easier but effective way is what I typically use on most steel hulls. I generally use a Sherwin Williams product Macropoxy 920 primer high solids over the prepared area. Then top coat with Macropoxy 646 fast cure epoxy below deck areas. If outside I will top coat with Acrolon 218 two part polyurethane for UV protection above the waterline. As long as you keep the carbon steel protected from oxygen molecules (oxidation) it usually does fine. Devoe,PPG,Sherwin,Americoat, and other paint suppliers will give you a free survey on what you will need for different applications. Also you can look up NACE or SSPC on the web and get great info on marine coatings. I have been in marine coatings for 20 years and key advice is get someone to look at it. No two vessels are the same. Send me your e-mail and I can give you some contacts in your area. Hope this helps.
  18. stiletto28
    so we had them look at it....
    Thanks heaps for the advice everybody. We asked one of the representatives of Met-Protect to come around and take a look at the interior spaces we've been working on. They do a lot of work with cargo ships, tugs, tankers, etc., mostly in the bilges. So at this stage we've cleaned off the old moldy water-soaked insulation and will have the interior grit-blasted to make sure that we don't miss anything with a grinder, etc. After that we'll use 2 part system from Met-Protect, which seems to be pretty sweet. Again I really appreciate all of the input!
    cheers
  19. wdrzal
    wdrzal Senior Member
    There is also a process that uses CO2 pellets and CO2 in it's supercritical state. Supercritical CO2 is a excellant solvent . IIRC the critical pressure is 1068 psi for scCO2.
    On a side note;
    You can google to read about scCO2 since you'll be hearing a lot more about it as it is finding it's way into HVAC systems and autos and eventually yachts.
    scCO2 in a supercritical ,transcritical system can carry 2.5 time the heat than standard CO2 refrigeration systems. The main engineering problem is the high side is ~2000 psi and the low side ~500 psi requiring a strong compressor and evaporator with micro channels. Seems current evaporators,at least on autos leak at 50 psi.:rolleyes:
  20. brian eiland
    brian eiland Senior Member
    St Augustine, Fl and Thailand
    Ceramic Bead Insulation Paint
    Hey Loren, ever hear of this?
    I am totally against spray on PU foam since it makes a mess of the hull and cannot weld or cut on the hull when fitting out. Furthermore, should condensation forms behind the foam where adhesive to the hull was not complete, it is hid from view and a disaster in the making. Loose PU sheets fitted to hull and deck behind paneling makes more sense. Polystyrene has no place on a boat for a many obvious reasons.
    However, my last steel boat built 2008/9 I used ceramic bead insulation paint (spinoff from NASA space program) on the inside of hull and deck. Thickly applied by brush and roller and having used white color, the hull is "neat" inside. Condensation does not bother this coating and should condensation formed inside the hull still it is able to drain to the bilge sump through its drain holes in stringers etc. Magic stuff and one can still cut and weld when doing fitting out if needed and just a matter of touching up the paintwork and applied fresh ceramic stuff over area.
    Best part, it does not burn and cost less than spray-on PU foam
    ...more here
    Steel hull isolation: alternatives to foam? - Page 10 - Boat Design Forums
