Click for Westport Click for Delta Click for Ocean Alexander Click for Abeking Click for Cross
Rudder Alignment
Discussion in 'Technical Discussion' started by Crglmb, Mar 11, 2008.
  1. Crglmb
    Crglmb New Member
    San Diego
    Need help with rudder alignment, on a 56' Sport yacht, Top speed 35knts.
    Are there any marine architect's out there, that have experience in this area.
    I have heard so many conflicting opinions toe-in or toe-out? Which is it and why. Thank you.
  2. CODOG
    CODOG Senior Member
    Bournemouth, southern England
    What sort of deadrise does she have aft ?
    Any sprayrails that run all the way aft to the transom ?
    Do you have prop tunnels ?
    How far forward from the transom are the rudders....say to the trailing edge ?
    What sort of distance do you have from the prop blades to the leading edge of rudder ...say as a fraction of prop diameter ?
    Do you have any running trim issues, such as excessively flat, or excessively stern down at speed ?
    What sort of rudders are they....totally flat plate, aerofoil section or wedged section ?
    Do they have cavitation plates ?
    You could see some lift at the stern at speed by toeing the rudders out on leading edges, depending on a few factors, and conversely see the stern sink down slightly at speed by toeing the rudders in on leading edges....Answering the above will allow a more considered answer:)
  3. Crglmb
    Crglmb New Member
    San Diego
    Have pics of boat out of water
    I have some pictures that I can email to you, my email is crglmb@cox.net
    Craig
