Click for Westport Click for Mulder Click for Northern Lights Click for Walker Click for Perko
RIB versus Whaler, Redux
Discussion in 'General Yachting Discussion' started by LuvBigBoats, Mar 5, 2023.
  1. LuvBigBoats
    LuvBigBoats Member
    Los Angeles
    Starting a new thread since the old one (https://www.yachtforums.com/threads/rib-inflatable-vs-fiberglass-hull.17582/) was from 2011 and goes through a lot more than I'm looking for.
    Trying to figure out whether I should re-tube my 13.5 widebody Nautica RIB (cost around $10k) or just break down and by a 13' Whaler Classic, Sport or Super Sport.
    Primary use is as a tender for my Offshore, but I want to be able to tow an inflatable tube with 2 adults on it (and 2 in the boat including driver). The Nautica tows 2 adults just fine (has a 70 hp 4-stroke Yamaha).
    The Whalers only allow 40hp on the 13' and I don't want to exceed what they state is max hp.
    Looking for some insight on:
    1. Can the Whaler tow the inflatable with 2 adults?
    2. How many adults can the Whaler hold comfortably?
    3. Is it true the Whaler is a much wetter ride than the RIB in any sort of chop?
    4. Is there a big diff in the ride of the diff models of Whaler (Classic, Sport, Super Sport) and even diff years of the same model?
    I like the idea that Whalers generally hold value. Find it crazy that re-tubing the Nautica is so expensive. If I get the Whaler, I would need to spend a decent amount for new chocks, new bridle (not sure if I need a bar), outfitting the Whaler with the stuff I already have on my RIB (stereo, fishfinder, VHF). Not even sure if I'll have the Offshore for another 7 years, but with regular maintenance the Whaler seems to stay new-looking, whereas that will not be the case with the RIB.
    Note the Avalon, CA dinghy dock limits dinghies to 14' and I need to comply with that. My Davit is rated to 1500 lbs. I think the Nautica wet is around 1000 if I'm not mistaken.
    Anyway, thoughts are appreciated.
  2. rtrafford
    rtrafford Senior Member
    Vero Beach
    Just love the simplicity of caring for and tying up a tube in the water adjacent to the vessel. Sits low to the water, and easy in/out, and you've already go the 4 stroke.
    I rebuilt my 430DL in 2019. I paid under $5k for the tube, another $2k for installation and misc repairs. Mine is 14', I believe.
  3. motoryachtlover
    motoryachtlover Senior Member
    smithfield, VA
    I have a 13’ AB dinghy with a 60 Yamaha and have owned 3 other dinghy’s. I have a close friend with a 1998 13’ Whaler (his was an anniversary model so Classic) with a 40 Yamaha 2 stroke. I have ridden on and driven the 13 whaler. I also owned a 16 SL Whaler. I am trying to establish that I am familiar with RIBs and small whalers.
    The 13 whaler is a really neat boat but that thing will beat the living hell out of you in even in an ICW chop. they are prone to porposing and weight placement is critical. All of that can be figured out and the solutions are online. But it is a bit finicky. As far as ride and spray I would rather have my 13 AB dinghy by a large margin. I don’t know how the other 13 Whalers ride. the 13 whaler will tow the inflatable with 2 adults. It can hold 4 adults comfortably but I don’t know if will plane 4 large men.
    I realize the inflatables lack the interior volume of the whaler, the tubes need constant work to keep looking nice and UV ultimately works them over but to me it is not a contest for a cruising tender. I would chose the inflatable. Another advantage of the inflatable is that it is less likely to damage itself or the mothership when loading and “docking” to the big boat. I used my 16’ whaler with my big to me boat and a modest runabout wake pushed the whaler into the swim platform while we were loading people and stuff and it penetrated the fiberglass of the whaler. So think about that as well.
  4. LuvBigBoats
    LuvBigBoats Member
    Los Angeles
    If it was $7k in 2019 I guess I shouldn't be surprised it's $10k in 2023, given the way things have gone up.
    Got to agree with you about the simplicity of tying up and not worrying about damage. The Offshore is in a pretty busy channel with a lot of wake, so when I launch the tender at the home port the potential for damage to the swim platform is real.
    Thanks for this real-world insight. It's more or less consistent with my other research. The Nautica handles chop pretty well. And per my comment above the potential for damage is there.
  5. rtrafford
    Vero Beach
    I used a private service for the replacement. I didn’t use the manufacturer factory. Vendor was located in Vero area and was quite a bit less expensive.
  6. LuvBigBoats
    LuvBigBoats Member
    Los Angeles
    Thanks--Nautica doesn't even exist anymore but apparently there's a family in Florida still making tubes for their RIBs. Wonder if it's the same people you used in Vero. Any chance you can PM me their contact info, please?
  7. rtrafford
    Vero Beach
    Sent. Yes, Nautica shut down a few years ago down in Hollywood. Novurania is up in Vero. These guys are nearby and formally employed with that manufacturer, I think.
    They did a very nice job for me, quite a bit less than Novu had quoted.
  8. LuvBigBoats
    LuvBigBoats Member
    Los Angeles
    Great, thanks
  9. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    I had a 01 Novurania 430 DL (14’), Found out earlier this year the tube was separating and was bad. I tried to find someone anywhere on the West Coast that would retube it. I couldn’t find anyone. I did find a guy down near Los Angeles that buys and refurbishes RIB boats and almost bought a Novurania from him with new tubes on it. At the last minute I come across a great deal on a 2016 430 DL in San Diego so I jumped on it. I was also able to sell my 01 boat to one of the refurbish guys near Seattle. My net out of pocket was $11k and I was able to upgrade from my older 50hp 4 stroke carbureted outboard to a 60hp fuel injected. Both outboards are Yamaha.
    The guy down near LA is in Carson and he advertises a number of boats on Craigslist and Marketplace. If you want his contact info let me know.
    I’ve riden in small Whalers and I own a 21’. As others have stated, those little 13’ Whalers will beat the crap out of you in any chop. They are usually heavier too. And be careful not to get one that the foam is waterlogged or they are real heavy.
    One of the reason the Novurania line is popular for tenders is they are a deeper V hull and tend to handle chop better. Case in point, when I picked up my newer 430 DL two weeks ago I had to run it about 8 miles across and down San Diego bay and it was literally blowing a Gale. That little 430 handled it great and I never felt unstable or unsafe.
  10. LuvBigBoats
    LuvBigBoats Member
    Los Angeles
    Thanks--sent you a PM
  11. rtrafford
    Vero Beach
    I have the same boat, but a few years older. Just repowered to the 60 from an older 50, and that makes a ton of difference in performance. New tubes, cables, gauges, and even a small plotter...what a great asset to have for fun as well as scouting channels and anchorages.
  12. DOCKMASTER
    Ketchikan, Alaska
    Yeah they are great little boats. I only wish they were easier to re-tube when it becomes necessary to do so. I'm really happy I found one with a later model fuel injected outboard. They start up much easier from cold starts. I'm swapping over my Simrad plotter/sounder from the old boat to the newer one. A must have in my area.
  13. rtrafford
    Vero Beach
    I shifted the steering wheel port a few inches, up an inch or so. Made room for a 7" display with the main gauges below the wheel. Pushed the VHF and stereo down below to clear the space. Really nice addition, sharing mapping and waypoint data etc from the mother ship.
