Click for Abeking Click for Northern Lights Click for YF Listing Service Click for Delta Click for Furuno
Retitling a documented vessel?
Discussion in 'General Yachting Discussion' started by CSkipR, Mar 21, 2015.
  1. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    I need to retitle a documented vessel and place it into a trust. Any idea what forms to use for this process?
  2. olderboater
  3. RER
    RER Senior Member
    Newport Beach CA
    ...or you can use a maritime documentation service. Which I recommend doing. Beware you are dealing with the federal government. If anything is incorrect even in the slightest, it will get kicked back to you for a re-do.
  4. olderboater
    I also recommend using a documentation service. Most of the time you could do the same thing, but it's that one time they handle problems or prevent mistakes that pays their way.
  5. Beau
    Beau Senior Member
    Beaufort, NC
    That is a big question you are putting to the forum. Are you getting professional advice on the trust? This seems more than just a title issue??
  6. olderboater
    Yes, we did pretty much assume a lawyer was handling the trust aspect. Hopefully that was a valid assumption.
    I'm going to introduce one other factor too. Maybe someone else can speak to experience on this but I haven't heard what, if any, issues people have with entry into other countries with a boat in a trust. This isn't so much what the legality is but what the agents recognize. They're somewhat use to Corporations and a little less so LLC's. I just don't know how they would react to a trust and be convinced that you've got proper permission to have the boat there.
  7. K1W1
    Very good advice, Trusts are coming under increasing scrutiny in my area of operation. There are some pitfalls that the alure of a quick fix trust disguise till its too late and the benefit you sought could be reduced or unavailable as originally intended.
    Take professional advice and if possible from a specialist who has setup a trust that is being used for similar to what you want your trust to do.
    Expect to pay accordingly for these specialist services.
  8. olderboater
    But keep in mind that not using the services of experts can be many times more expensive.
  9. K1W1
    That is the exact reason I posted that line.
  10. CSkipR
    CSkipR Member
    Heres the explanation. Its my vessel that's been documented under my name since 08. Now I want to put it into my trust so I have to submit the proper paperwork.
  11. olderboater
    I understood the situation from your initial question, but....
    The devil is in the details, which none of us have, along with us not being experts in the field. We don't even know basics such as the type trust, the state in which the trust is formed (guessing Florida but this isn't the sort of thing to guess at), and so much more. We could give an answer that is correct in most situations but could be very wrong in yours. I assume you've used a lawyer in setting up the trust, but hope also you've consulted with one in the pros and cons of putting your boat in the trust. Once that is fully resolved then my advice remains to use a documentation service.
    This question is far more than which forms to use. I pointed you to the forms, but I'd not advise you to use them. Not trying to be difficult, just advising you this is far too complex a subject requiring professionals in two different fields and requiring them to have all the information.
  12. CSkipR
    CSkipR Member
    The forms were exactly what I needed. Will handle the documented transfer. My attorney recommended me doing this. Thanks for the info.
    Skip
  13. Beau
    Beau Senior Member
    Beaufort, NC
    Hi Skip
    Not my intention to pierce any privacy, just learn. What is the intended benefit of putting a depreciating asset in trust?
  14. CSkipR
    CSkipR Member
    My attorney recommended putting it in the trust in case something happened to spouse and myself it would not have to go through probate.
  15. Beau
    Beau Senior Member
    Beaufort, NC
    Thx Skip. How's have those Mans been running?
  16. YachtForums
    As this thread is not a technical issue, it has been moved to the General Discussion forum.
  17. CSkipR
    CSkipR Member
    Beau,
    Thanks for asking they have been running well.
    Skip
  18. Capt Ralph
    Thought wills and executors kept your wishes intact & out of court.
    All were leaving behind is debt.
  19. CSkipR
    CSkipR Member
    RC,
    It depends but some of what is in a will still has to go through probate. Just means it takes longer and probably costs more.
    Skip
  20. SFS
    SFS Senior Member
    Tampa
    Also, a will can always be challenged, and sometimes challenges are successful.
