Click for Delta Click for JetForums Click for Perko Click for Cross Click for Westport
Repowering question
Discussion in 'Engines' started by Cdndewey, Oct 18, 2021.
  1. Cdndewey
    Cdndewey New Member
    Chemainus BC
    I'm buying a 28' Silverton with a 350 Mercruiser and a Walter V drive. I would like to replace the power system eventually with a diesel.
    Anybody have experience with doing that or suggestions before I take the plunge?
    The Walter V drive raises the motor height pretty tall. You may be hard to find a short Diesel engine and exhaust riser to fit under the deck.
    I would measure this out first before your purchase and diesel conversion get started.
  3. Cdndewey
    Cdndewey New Member
    Chemainus BC
    Sounds good...the more information the better...thanks.
  4. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    We've fitted quite a few Hyundai straight 4 and V6 diesels to replace gas engines, either shaft drive or outdrive. Maybe worth a look.
    http://www.hyundaiseasallusa.com/
    f3504x4ps and Cdndewey like this.
  5. Cdndewey
    Cdndewey New Member
    Chemainus BC
    Thanks...I'll look into that.
  6. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    I'd suggest a careful cost analysis alongside your thoughts about what you expect to accomplish (end up with).
    I know some conversions from gas to diesel can get into the $100K neighborhood -- although one of those in a 35 Bertram also included new gears, new shafts, and a new genset too -- and the boat ends up being worth not much more than it would have been with new gas engines.
    Not intending to sound negative, just offering ideas to think about...
    -Chris
  7. Pascal
    How old is the boat? Unless you find a diesel which will fit that Vee drive and shaft, I don’t see this being a viable option as the costs will quickly escalate if you have to replace the shafts, engine bed etc.
    The weight of the diesel vs gasser may also cause issues. And if you increase HP to compensate for the weight you will have to increase shaft diameter and likely beef up the stringers. Silvertons are not Bertrams....
  8. Cdndewey
    Cdndewey New Member
    Chemainus BC
    A cost analysis is a definite must. I'm retired and on a fixed income so finances definitely comes into play. My reasoning is the cost of cruising because there's lots to explore where I live. I'm not overly concerned with resale as I have a son and two grandsons that would be happy to inherit it.
  9. MBevins
    MBevins Senior Member
    Windsor On. Canada
    Problem is you probably won't save any money in the long run. Remember you're only working with difference in cost between the two fuels. Even with efficiency of diesel calculated in.
  10. Capt Ralph
    It may be less expensive and easier to just purchase a diesel boat if you must have a diesel boat.
    For the small amount of hours that the best of seasons can offer you, maintaining a gas boat may be the better boat, short & long term.
  11. ranger58sb
    Chesapeake Bay, USA
    With some (many) boats, all you have to do to save fuel expense is to slow down to under maximum theoretical hull speed. That's a displacement hull notion, but it works well enough for other hull forms, and I'm guessing it works with gas engines, too. Sea states don't always cooperate, but then again if you're not schedule-driven, waiting out weather isn't always a hardship.
    And/or just buy a diesel boat and sell the gasser. Probably less expensive than doing a conversion.
    But see what your own cost analysis says, first.
    -Chris
  12. Pascal
    that works well on pretty much all boats over 50’ where you ll get a hull speed of 9 kts and up. On a small boat like this though hull speed is going to be a torturous 6 kts ...
  13. Cdndewey
    Cdndewey New Member
    Chemainus BC
  14. Cdndewey
    Cdndewey New Member
    Chemainus BC
    Six knots is okay for me...I'm in no hurry to get anywhere.
  15. Cdndewey
    Cdndewey New Member
    Chemainus BC
  16. Cdndewey
    Cdndewey New Member
    Chemainus BC
    Out here on the west coast you can get a lot of boating in year round. The cruising that I want to do would consume a lot of gas and the fuel docks wouldn't be frequent enough for me to fuel up. Diesel will extend my cruising range and lower my costs.
  17. Capt Ralph
    Are you thinking going slow in a diesel boat "will extend my cruising range and lower my costs" dramatically over gas at the same speed??
  18. Cdndewey
    Cdndewey New Member
    Chemainus BC
    Yes...6 to 8 knots is fine for me. Lots of logs and deadheads where I plan on going so I'll be in no hurry. Not to mention...I'm retired and have no urgency to be anywhere.
  19. Pascal
    8 knots is the worst speed on a 28 footer. You ll burn twice the fuel you would at 6kts.
  20. Cdndewey
    Cdndewey New Member
    Chemainus BC
    Okay...6 it is.
