Click for Abeking Click for Westport Click for Glendinning Click for Ocean Alexander Click for CL Yachts 99X
Removing Port salon window on a 4207 Carver
Discussion in 'Carver Yacht' started by riverat, May 2, 2013.
  1. riverat
    riverat New Member
    Richmond, Va
    I have a rainwater leak on the port salon window. It leaks into the aft cabin and engine compartment. I cleaned the track out thinking one of the weep holes was plugged.... it's never that easy. I need to remove the window assembly and reseal it. Not having done this before, I'm a little skeptical about this task. Has anyone had any experience with removing the salon windows? Is there a rubber seal around the window that will need to be replaced or can I use a silicone sealant? Any help would be greatly appreciated.
    Thanks,
    Rivarat...
