Click for JetForums Click for Westport Click for Mulder Click for Cross Click for Glendinning
Remove rust without damaging gel coat
Discussion in 'General Yachting Discussion' started by John Sakovits, Sep 20, 2016.
  1. John Sakovits
    John Sakovits Member
    Portsmouth nh
    I know there are a number of products that remove rust stains but from what I understand most will etch the gel coat. Is there a product that will remove rust stains but will not etch or harm gel coat ?
  2. RT46
    RT46 Senior Member
    Wink
    Yup Whink. It's in a brown bottle and can be found in some grocery stores by the laundry stain stuff. Pour a little on, watch the rust disappear, and rinse it off
  4. John Sakovits
    Portsmouth nh
    Thanks for the quick feedback. So Whink makes a lot of products. Which one is it ?
    Thanks again!
  5. YachtForums
    Probably the one labelled 'rust remover'. :rolleyes:
    Whink is good. Bar Keeper's Friend will also work.
  6. John Sakovits
    Portsmouth nh
    It looks like this is a acid based product. Safe to assume that folks have not seen any deterioration or porosity in the gel coat after using Whink ?
    Appreciate the feedback.
    No damage to gel coat or paint with using whink that I have seen. I've been using whink for over a decade. The brown bottle labeled "rust stain remover".
  8. John Sakovits
    Portsmouth nh
    Any issues with Whink rust stain remover and vinyl striping ? Just trying to be safe instead of sorry.
  9. Capt J
    No, it's made for removing rust stains on clothes (laundry) so it's not that harsh.
  10. g collis
    g collis Member
    Saint Simons Island Georgia
    I've had good luck with On Off. Just don't breath the mist.
  11. maldwin
    maldwin Senior Member
    Dark Harbor Me/ Hobe Sound Fl
    I have just had to paint my 2008 Nordhavn hull due to someone using Wink on the rubrail. It ruined the gel coat below. I assume the deckhand, who should have been using Fritz for that project, was not rinsing enough. Still, i will never use Wink again near my Gelcoat.
    Best,
    Maldwin
  12. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    Like any acid based cleaner, don't leave it on for too long and rinse well. Gels, like Y10, linger and will discolour gelcoat over time.
    I use Corrosion X Rust Remover.
  13. praetorian47
    praetorian47 Senior Member
    Bayport, Midland, Ontario
    I use a product from sea-shield called rust stain remover. It will strip wax, but does not damage the gelcoat. I have a through hull the leaves a rust stain all the time, so I clean it off a few times a year with this. Just spray on, let it sit a few minute and rinse. Works well for me, better than anything else I've used and no adverse affects I've been able to see.
