Click for YF Listing Service Click for Nordhavn Click for Abeking Click for Ocean Alexander Click for Walker
removal of Stainless Steel Cutwater
Discussion in 'Technical Discussion' started by tball, Feb 11, 2007.
  1. tball
    tball New Member
    vancouver
    We have to remove a Stainless Steel Cutwater from the bow of a aluminum yacht. I am worrried that once we remove the cut water that we will also pull off the paint and fairing that is around the cutwater. The cutwater is thru bolted to the hull and also adhered to the hull with 5200. Any suggestions or tips.:eek:
  2. AMG
    Hi, I don“t know exactly without seeing it, but cut with a carpet knive and heat the piece to soften the glue could be a solution. Hair drier or paint remover as heater.
  3. CaptTom
    CaptTom Senior Member
    Palm Beach to Ft Lauderdale
    tball,
    The 5200 is very tough to get thru or take apart. Cut/score with a sharp knife like AMG suggested but you may have to "saw" through it also. I've heard of folks who have used piano wire or the like to saw thru the 5200. Not sure what angle or access you may have to do that. Scoring should help prevent pulling off the paint.
  4. Garry Hartshorn
    Garry Hartshorn Senior Member
    3M Does make a solvent for 5200 not seen very often but it does work even if a little slow
  5. SeaEric
    SeaEric YF Historian
    out on the dock
  6. CaptTom
    What does Debond due to the paint finish? Any discoloring or blistering?
  7. SeaEric
    out on the dock
    I would certainly mask the work area well to prevent surprises. Beyond that, I'd say read all of the fine print on the product.
  8. Ken Bracewell
    Ken Bracewell Senior Member
    Somewhere Sunny
    Debond won't hurt the paint. But my 2 cents is that you're probably going to have to do some paint work on that area anyway. You'll likely find that the stainless, aluminum, and salt water aren't very good friends.
