Click for Perko Click for Perko Click for Abeking Click for Glendinning Cick to Clean Black Water
Recommendations on Kohler generator
Discussion in 'Generators' started by Jnicholas, Mar 29, 2026 at 10:16 PM.
  1. Jnicholas
    Jnicholas Member
    Long beach ca
    Have issue, appreciate some advice.
    Generator has been working well. Had an easy winter but still ran a few minutes with a small load a couple of times a month.
    starting my spring maintenance and decided to have a reputable co.do a fuel polish on 260 gal in two tanks. All went well. Changed racors, primary and secondary fuel filters on engines, and the kohler fuel filter.
    engines started up great. No leaks. Generator turned over a couple of times slowly then starter just clicked. Charger is working, assumed bad battery. Replaced battery today, battery shows full charge but same sound like dead battery.
    probably above my pay grade but what should pro be checking first.
  2. Jnicholas
    Jnicholas Member
    Long beach ca
    3JH2L-TE-K
    I believe this is the model number. 18 kw generator
  3. Capt Ralph
    Go thru your battery cables, cable ends (lugs), and switch connects carefully. Positive and negative leads.
    About every 5 years my big gen-set does the same thing and it's always the hot cable end loose on the starter.
  4. Jnicholas
    Jnicholas Member
    Long beach ca
    I cleaned the lugs on the battery as good as I could but they still were not “shiny”. Normally I would have taken my small dremel to it it cleaner really well but it was at home. I did not check on the starter. Thanks for the tip!
  5. Pascal
    I agree with Ralph. Start with the cables at the starter incl ground cable to block. If that fails I woudl test the starter itself
