Click for Glendinning Click for Mulder Click for Cross Click for Abeking Click for Westport
Raymarine Chart Plotter Problem
Discussion in 'Electronics' started by Jill Britton, Jul 21, 2023.
  1. Jill Britton
    Jill Britton New Member
    Portsmouth
    I’ve got a Raymarine eS128 MFD chart plotter.
    The screen keeps changing on its own and it won’t hold a chart. The touchscreen also sometimes doesn’t work.
    Has anyone else had similar problems with this model…and did anyone get it repaired?
    We’ve been told that Raymarine won’t/can’t fix it!
  2. Thisisit
    Thisisit Member
    Midland, Ontario, Canada
    It could be a touch screen issue. Perhaps the screen is getting ghost inputs. There should be an option to disable the touch screen feature. Try that and simply use the manual buttons until you have a permanent fix.
  3. Pascal
    How old is it ?
  4. Thisisit
    Thisisit Member
    Also, check to make sure that all of your peripherals (if any) are connected properly. Check that you have a good ground, a good drain connection and stable voltage supply. Check to make sure that the NMEA network (if networked) is properly terminated at both ends.
  5. Jill Britton
    Portsmouth
    We think it’s about 5-6 years old, but we’ve only just purchased/installed it…
  6. Jill Britton
    Portsmouth
    Thanks for all the suggestions. Chat online doesn’t fill us with confidence that this is fixable so any suggestions are much appreciated…
