Click for Westport Click for Northern Lights Click for Furuno Click for Burger Click for Burger
Raw Water and Hydraulic hose life
Discussion in 'Technical Discussion' started by bayoubud, Jun 6, 2017.
  1. bayoubud
    bayoubud Senior Member
    Florida
    How often should raw water and hydraulic hoses be replaced on engines, generators, a/c's, stabilizers, and any equipment that is ran a lot?
  2. Pascal
    I ve seen SS braided hydraulic hoses failing after a couple of years while others may last 10 or 15... usually quality raw water hose will last a very long time... 15, 20 years.
  3. bayoubud
    Florida
    I have heard 5/6 years on wired engine raw water. Longer periods for hydraulic if no cracking. Recently looked at a 2005 b0at with hoses dated 20o4. Thought that was risky. Seems ER hoses would not last as long because of heat.
    Yeah those figures are about right......visually once the wire bound hoses show any cracking I change them. Hydraulic usually show signs of getting old too. It's also how tight of bends they do.
  5. bayoubud
    Florida
    Capt J, my last surveyor said the same, he recommends hoses on engines, gens, and equipment which runs often be replaced every 5 years, but only writes them up if cracked. I am looking at this mainly from a buyers side that often does not get addressed in surveys, mostly bad hose clamps.
