Click for Perko Click for Northern Lights Click for Cross Click for JetForums Click for Walker
RainX on ez2cy enclosures?
Discussion in 'General Yachting Discussion' started by Beau, Jul 25, 2017.
  1. Beau
    Beau Senior Member
    Beaufort, NC
    Hey Folks
    Has anyone used Rainx on their ez2cy ?
  2. Prospective
    Prospective Senior Member
    New England
    I would not use the regular stuff. They do make a rain-ex for plastic but I have been reluctant to even try that on my new poly-carb enclosure...
  3. YachtForums
    RainX is alcohol based. It will fog Eisenglass. Not sure on EZ2CY, but a carnuba based wax should repel water without attacking plastic.
  4. Beau
    Beau Senior Member
    Beaufort, NC
    Carnubra it is, thx. Carl, what do you think of a collonite?
  5. YachtForums
  6. ReelPlumber
    ReelPlumber Member
    Fort Pierce
  7. bayoubud
    bayoubud Senior Member
    Florida
    Try some Mequiar's quick wax detailer. Just too easy to use... a polymer not a wax...sheds water well. Can use it on most everything that shines outside and inside.
  8. Bill106
    Bill106 Senior Member
    Beaufort NC
    Just tried the Rain-X for plastic for the first time on our newest 37 express I delivered to the vineyard last week with an acrylic enclosure (Everclear) and it worked just as well as it does on my trucks windshield. I didn't see any fogging or negative effects. I'd previously tried Plexus 210 and Collinite but neither worked 1/10 as well as the Rain-X did.
  9. Capt J
    Clean the ez2cy with either aquatech or IMAR strataglass cleaner......then wax with either Collinite insulator wax (recommended by EZ2CY) or the IMAR strataglass polish if the EZ2CY has fine scratches....the insulator wax works REALLY well and is the best for EZ2CY usually.
  10. trmnewt
    trmnewt Member
    Rochester
    +1 on Collinite Insulator wax
  11. Beau
    Beau Senior Member
    Beaufort, NC
    Thanks Capt
  12. Capt J
    With the insulator wax, rub it on there a little to work it in, let it dry completely and rub off with a microfiber. It goes on and off pretty easy and a little bit goes a long way.
