I have a 1995 50’ Ocean Alexander and I would like to upgrade my radar. What would be the general cost and is this something that I could do myself ?
Many people install their own radars. The prices are all over the board, so maybe go to a chandler and discuss the selection process with a knowledgeable product specialist. Bear in mind, that a radar can be a very critical safety tool. If installed incorrectly, it may lead you to think your course is clear when it is not. Also, reliability is affected by proper attention to detail when installing, such as adequate power supply, appropriate wire and wiring connections, waterproofing, selection of installation materials, mounting, and final adjustments. Perhaps peace of mind would be worth the cost of installation.
Thank you for getting back to me everything you said is so informative some of those things I didn't think about
First question is where and how do you use the boat. If you are up north like New England where fog is very frequent then indeed a good radar is important. If you re down south what you have maybe enough. I have seen way too many boat owners who feel they have to spend a lot of money and get the latest electronics even though they don’t need them. Then of course it s hard to suggest an upgrade without knowing what you have...
My equipment is likely 20 years old or older. It is a Raymarine open array and a C80 Classic display. Very happy with the performance and not looking to replace until it breaks.
Newer equipment is actually easier to install these days. The Furuno radars I've helped install have an ethernet cable and a power cable to run to the mast. We've taken out a thick cable and replaced them with two smaller more flexible cables. Then all the other instruments are now linked with NMEA2000 links. So there are very few finicky little wires to join like there once was. There are still the installation set ups of lining up the heading on a target and it's important to use it in good daylight to confirm it's operation.
