Click for Cross Click for Glendinning Click for Delta Click for Northern Lights Click for Mulder
Quotes from YF posts
Discussion in 'YachtForums Yacht Club' started by JWY, Mar 18, 2021.
  1. JWY
    JWY Senior Member
    Just read this on another thread:
    "There is Hull No. 5200 which is a 107 Explorer currently under construction for delivery by late 2022."
    Not interested. Personally, I prefer duck tape.
    Ok, so you didn't laugh. Good excuse for a new thread?
    Took me a moment to catch that. Love ya Judy, but don't quit your day job.:D
  3. Norseman
    Norseman Senior Member
    Me too, had to read it twice.
    A bit of dry humor is always good.
  4. JWY
    JWY Senior Member
    Whew, good thing you didn't say wet humor - it is a boat! Ok, back to my day job...
  5. Steve Hubbard
    Steve Hubbard New Member
    Michigan,South Carolina
    so my daughter says to me: "dad if your boat's name is Sea Witch, and it sinks do you rename it Sandwich?"
  6. JWY
    JWY Senior Member
    lmao!
  7. Norseman
    Yes Judy, Good advice from New York, stay a steady course at your present occupation and keep them dry jokes coming now and then. :p
    Here is one of my jokes:
    “Why was Jesus not born in Sweden?
    Answer: Nobody could find 3 wise men, and a Virgin”
    (Sorry Lars) Grabbing hat and coat now and leaving the room. :eek:
    Bonus:
    “What does it say under the beer bottles in Sweden?
    Answer: Open in the other end”
    Aye, I won’t quit my day job either..In fact a member of this forum contacted me today about a sightseeing charter on Odin, should be good, having boat guys as passengers, less work for the solo Captain. :cool:
  8. YachtForums
    I could make an argument for using Gorilla tape over 5200. I used it to tape a piece of cardboard to an exterior wall. When I removed the tape, the stucko came with it.
  9. Ken Bracewell
    Ken Bracewell Senior Member
    Somewhere Sunny
    I am not a fan of 5200, and heavily restrict it's use on any of my boats. We don't call it "fifty-two-hundred", but rather "eff-the-next-guy-glue"
  10. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    Sorry I’m going off course...but what sealant do you prefer? And why?
    here’s some humor...Since I already know it all.., I should have the answer !
  11. chesapeake46
    chesapeake46 Senior Member
    The gorilla spray adhesive is to hair gel as gorilla tape is to a bikini wax.
  12. JWY
    JWY Senior Member
    It might have "taken a moment" for NYCAP and Norseman to get mine, but jeez, I had to spend a few minutes of head scratching to figure yours out. Thanks for not including photos for hairification, I mean clarification.
  13. Ken Bracewell
    Somewhere Sunny
    Therein lies the issue. 5200 is an adhesive/sealant, rather than a sealant. 3M 4000 is an option.
    BTW- my post was auto-corrected, and should have read "eff-the-next-guy-glue" (admin edit: corrected)
  14. NYCAP123
    Now meanwhile I caught that right away, but all I could think of was OUCH!!!
  15. Norseman
    Ouch indeed..:(
    Spent a few hours today and yesterday removing and re-bedding 6 thru hull fittings, 5 of them was installed with regular caulk, perhaps 3M 101, the single mushroom to the right was bedded in with 5200 and that one took me more time than the other 5 combined..:mad:
  16. JWY
    JWY Senior Member
  17. chesapeake46
    I have had pretty good luck by heating a sharp putty knife with a heat gun and forcing it under the fitting to be removed. Still a lot of effort tho.
  18. NYCAP123
    In an application like Norseman's you might find it easier to use a razor blade.
  19. cleanslate
    Cherry Hill, NJ
    Ahh! Chesapeake torture! Covers both sexes.. I’ll be sleeping with one eye open on that Post of yours ...
  20. Norseman
    Yup, used a razor blade but afraid of scratching the gelcoat: The surface is not 100% flat/level hence the blade tried to bite into the surrounding area.
    Tried gently with a small chisel, and with a nail on my right thumb: Not a good idea, the nail bent back and I swore like a drunken sailor.o_O
    This tool combo kind of worked by cutting the 5200:
    One can see some white residue on the drill bit..
    The old plastic thru-hull fitting was removed with brute force and by turning it so the threads helped a bit: I guy pushing from the inside, another guy, me, pulling from the outside. The hard work was cleaning and removing the old caulk so the new sealant would stick.
