Click for Northern Lights Click for YF Listing Service Click for Abeking Click for Westport Click for Burger
pvc floor mats
Discussion in 'Technical Discussion' started by franzmerenda, Feb 15, 2012.
  1. franzmerenda
    franzmerenda Senior Member
    La Spezia, Italy
    Hi Gentlemen,
    I'm looking to find some PVC tubular mat for engine room floor covering.
    The kind I'm looking for is the blue one used in Donzis Sportfish engine rooms.
    Many thanks,
    franz:)
    If I'm thinking of the right stuff (Dri-Dek) it comes in interlocking squares and can be ordered from WM: Search Results at West Marine &TypeAhead
  3. RVN-BR
    RVN-BR Senior Member
    South Florida & Mediterranean
    Since on the topic, at least somewhat, what are the different (similar) types of protection/maintenance/running mats that yachts have?
    When involved in private aviation we used to have maintenance runners for whenever the jet is out of service. I suppose this would be good in some areas for yachts too and would like to look at options. (to have service people be able to board with their work close, etc, and not be completely freaking out the crew)
    It would have to be different for indoor and outdoor obviously. Custom cut will probably be best...even though some "custom cutting" may just be the crew cut it...
    Any brands/materials you guys can recommend? for covering the teak deck, carpets?
    Anyone have experience with anything slightly more durable/presentable for entertaining semi-unruly people? (obviously we never want unrulies aboard, but when you have a lagrer-ish group, one thing or another can get spilled. a protective mat of sorts on the delicate teak would make crew and guests alike more at ease. smoking protection is also a plus that comes to mind should someone drop a cigarette or worse a cigar for more than a split second)...
    Any ideas? Comments on the ease of storage of these solutions would be cool too...
  4. NYCAP123
    I always put down that thin plastic carpet covering for the off-season. Many boats use canvas carpet covers that snap in place for in-season, but they cost almost as much as new carpet. ScotchGuard is a wonderful invention. Last year we had a guest dump a jar of salsa.:eek: Quick clean-up followed by a professional cleaning was all that saved us. Many boats keep a basket at the salon entry for shoes. As for teak, there's nothing much to do that I know of other than ask for boat shoes, restrict smoking, keep teak cleaner, oil and some fine sand paper on hand. Sometimes that thick blue plastic is used at shows, but you'd never have it on a boat in use. Stregically placed mats also help.
  5. franzmerenda
    La Spezia, Italy
    Thank you for your usual prompt and specific feedback.
    Actually the one I have now is Flexiair (the one in the picture below), but it's black and with some "miles" on it.
    It's nice because you can trim it easily using a cutter.
    I was just wondering if I would be able to find it somewhere close to Ft. Lauderdale, since there's a boat of a friend of mine leaving soon from there to Italy:eek:
  6. sagharborskip
    sagharborskip Senior Member
    Sag Harbor, NY
    You're looking for Teproflow Wet/Dry vinyl matting...comes in rolls in a variety of widths that you can cut/shape to your need.
    National Marine has it in stock...
  7. franzmerenda
    La Spezia, Italy
    Great!
    Thank you very much.;)
  8. Capt. Mike
    Capt. Mike New Member
    Nashville TN,
    You might look at the truck bed liner. I saw it in a roll at Tractor Supply Co. Two days ago and not a bad price.
    http://www.tractorsupply.com/
  9. travler
    travler Senior Member
    roche harbor wa
    i go to home depo and buy the 3 ft square black mats that are rubber and thy work just fine cut to fit
    travler
