Click for Burger Click for Ocean Alexander Click for Walker Click for CL Yachts Click for Abeking
Proper PSI on 8v92 expansion tank cap
Discussion in 'Engines' started by Pio Casadey, Jun 15, 2017.
  1. Pio Casadey
    Pio Casadey New Member
    Port Otange florida
    What is the proper PSI that should be used on the expansion coolant tank cap on the Detroit 8v92
    13 psi
  3. Capt Ralph
    I was thinking 7 to 9. You running a closed system? Give me a serial number and I'll get what the factory specs.
    Where is Port Otange FL?
    Maybe Port Orange, South Daytona?
  4. RT46
    RT46 Senior Member
    8 psi is the number that pops in my head
  5. Just Cruisin
    Just Cruisin Member
    Detroit, MI
    I have 8v92's TA-DD - 1994. I just had to replace the old cracked caps and found the caps and tank are actually a caterpillar part. The caps only are 3362022. My system indicated 7 psi. New caps are vented but the boat ran at 168 degrees with no issue.
  6. Pio Casadey
    Port Otange florida
    OK checked the caps on both engines they are 7psi. Both are kind of rough and they are not DD. Can I use any type of cap? say from napa etc or do I need to get from DD.
  7. Capt Ralph
    Yes
    The better part guy (person) at the counter can find the correct cap. There will be two different caps. Go for the closed system. If not already, upgrade your system to a recovery system. Your bilges would welcome it.
