Click for Cross Click for Delta Click for Westport Click for Northern Lights Click for Nordhavn
Prop Size For 35' Viking 1986
Discussion in 'Viking Yacht' started by ERTW, Jun 20, 2018.
  1. ERTW
    ERTW Member
    North America
    Trying to figure out optimum prop size for 35' viking convertible with twin 3208 TA 375hp , 1.512:1 ratio gearbox. Currently running 22 x 24 3 blade with no 7 cup. What are others running? I find I'm under rpm by about 300rpm.
    That is a lot of pitch.
    You called Viking yet?
  3. ERTW
    ERTW Member
    North America
    Yes I emailed with viking and the hull number calls out for a 22 x 24 3 blade but not sure about the number cup they think possibly no. 2 cup.
  4. sheraton
    sheraton Member
    Barnegat Bay New Jersey
    My Friend has the same exact boat and power, he has 22 x 23 with no cup.
  5. Gene Trevail
    Gene Trevail New Member
    Jacksonville Florida
    I have a 86 35 Viking Sportsfish Convertible with twin 383 Stroker mercruiser engines repower from the 454 mercruisers. Any recommendations on the prop size for these gas engines or will the old props work? Ty Gene
    You would be amazed what that new engine will do compared the the old LBC. I would give the original wheels a try and IF needed, a lil pitch removed.
    The important thing to watch, you make WOT RPM per spec with good load on board. Full fuel, water and the gear and people you usally cruise with.
