Click for YF Listing Service Click for Burger Click for Delta Click for Westport Click for Abeking
Problem With Pop Rivets On A Mast
Discussion in 'Technical Discussion' started by discokachina, May 14, 2013.
  1. discokachina
    discokachina Senior Member
    A friend of mine is up from Bocas and is working on replacing a steel sail track on his aluminum mast that has a total material thickness of track and mast of 1/4".
    He wants to use pop rivets to avoid drilling and tapping 200 holes.
    1. Which kind of rivet material should he use: monel or steel or other?
    2. For the 1/4" thickness of the material he is trying to use 3/16" diameter rivets, in that case which length rivets would be best to try?
    Any other suggestions?
  2. K1W1
    Why is he putting a steel track on his aluminium mast?
  3. discokachina
    The boat is a Morgan 462. He wants to continue using the Harken steel track because of its strength. He uses double stick tape to hold the track and provide a barrier/bedding layer. He then uses tefgel on the rivets to provide a barrier between the steel and aluminum.
  4. K1W1
  5. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
