Click for Northern Lights Click for Abeking Click for JetForums Click for YF Listing Service Click for Nordhavn
problem w/ 24 V electrical panel reading
Discussion in 'Electronics' started by Goodlife, Aug 19, 2011.
  1. Goodlife
    Goodlife New Member
    columbia island
    I have a 2004 Silverton 48C. I just replaced the 4-8D wet batteries w/ 4 AGM Odyssey batteries. batteries installed. everything works (as far as I know) but for some reason the electrical panel in the salon, the 24V lines when switched on start climbing... "8V, 10, 15, 19v, 20, 21...24v's" and then drop to show "8V's" or "3V's" or "9V's". I do not understand why. can anybody help me w/ this. when I read the V's on the batteries w/ my hand held multimeter they read 12V & 24V when read in series.
  2. K1W1
    Did it do this previously?
    What made you decide to change all batteries? I hope it wasn't a bad reading on the Panel Meter.
    Can you take out the Panel Meter and with a couple of bits of wire connect it to the batteries direct?
    Are you using a hand held digital volt meter to check the batteries or a moving coil type one?
  3. Goodlife
    Goodlife New Member
    columbia island
    Batteries were dead. Not an issue before. Checked new batteries wn handheld digital multimeter. Have not connected display to batteries yet. Good idea.
  4. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    Is the panel meter digital or analog?
    Does the meter do this whether the charger is on or off?
    Or does it do it either way?
    How about when the engine/s are running?
  5. Goodlife
    Goodlife New Member
    columbia island
    panel is digital.
    I haven't checked any of these items yet. I just noticed that the panel was making these readings when we came back from a day cruise. Engines & generator off. shore power on.
    I will try these suggestions and let you knpw the results.
    Thanks,
  6. Marmot
    You are aware that there is a critical difference in charging voltage between wet cells and AGM, right?
    I suggest you contact the manufacturer of your charging and monitoring systems to ensure both are functioning properly for your new battery.
