Click for Ocean Alexander Click for YF Listing Service Click for Abeking Cick to Clean Black Water Click for Cross
Potable water level sender
Discussion in 'Cabo Yacht' started by AHammitt, Nov 15, 2025 at 12:23 PM.
  1. AHammitt
    AHammitt New Member
    Saturday
    San Pedro, CA
    Trying to replace the level sender in the potable water tank on a 40' express 2011. I know the tank is forward of the engine room and aft of the bilge access in the cabin, under the head. The only access I can find to the tank is inside the sink cabinet in the head, but the sender in not in that location. Any thoughts? Could it be under the head? if I removed it? Does not look like there is any access there to me. No access panel under the companion way stair in the deck. Hate to just start cutting holes in the boat to find the sender. Hoping someone has the knowledge of where to look for it.
    No it will not be under the toilet. It should have access to the sender without destroying anything on the boat, follow the fill outside to where it would line up inside the boat and look centerline. It's been a good while since I've been on a 40'. Lift up the steps going down to the salon and look underneath there, if there's a built in trash can pull that out. OR, it's behind the breaker panel which will swing open.
