Click for Glendinning Click for Mulder Click for Perko Click for Furuno Click for Abeking
Porthole windows stuck shut
Discussion in 'Technical Discussion' started by Zud, Jun 2, 2017.
  1. Zud
    Zud Senior Member
    PA
    Any miracle ideas to unstick porthole windows that seem stuck to the rubber seals...would like some fresh air !
  2. 30West
    30West Member
    Holland, Michigan
    Pictures?
    Spray Windex through the screen from the outside, keep it wet, works better on a cool, damp day.
    Window trim knives are bent to get behind glass, might be what you need.
  3. Zud
    Zud Senior Member
    PA
    Thanks, 30West, will give it a shot tomorrow
  4. T.K.
    T.K. Senior Member
    Cairo - Egypt
    Have you tried pushing them in from the outside? Take a dinghy alongside the boat and give it a try. Make sure the catches are open.
    Neptunus used a lot of non opening portholes. But if they have the dogs on the inside, then it's just a stuck gasket. I think you can run a thin putty knife between the porthole and gasket on the inside to help break them loose.
  6. Zud
    Zud Senior Member
    PA
    Captain J, thanks, they do have the dogs hence my newbie assumption that they open. I think a combo of the windex, helping from outside, thanks T.K., as well as the thin razor knife should do the trick. Hope so as I hate to waste the cool breezes mother nature is supplying us with. Don ???
