Click for Mulder Click for Furuno Click for Burger Click for Burger Click for Abeking
Port fuel tank air locked
Discussion in 'Luhrs Yacht' started by PPD, Jul 10, 2020.
  1. PPD
    PPD Member
    CT
    Anyone know the least destructive way to access/replace the fuel fill and vent hoses on a Tournament 400?
    It looks like I have a sag in the fuel line, preventing me from filling the tank.
    thanks
  2. rtrafford
    rtrafford Senior Member
    Vero Beach
    No idea of the conditions you're facing, but if you can see the "sag", can you implement anything to remove that dip?
  3. NYCAP123
    If you're seeing a sag and it's preventing you from fueling I'd say the line is compromise, and simply removing the dip could lead to a blowout. You should be able to disconnect at the tank and pull it up and out. It may be caulked at the deck. I'd be hesitant to install my own fuel line though. Have you tried snaking the vent line? If that gets clogged by a spider web, etc. that could be your problem.
  4. rtrafford
    Vero Beach
    I believe that type of rot or failure can be seen and felt with a close inspection, but often simple temperature impacts of engine heat can allow a hose to shift that isn't otherwise supported well enough, making no statement at all as to compromised hose integrity.
  5. PPD
    PPD Member
    CT
    So I was able to see the fuel fill hose and the boat seems to be designed with the deck fill fitting basically straight above the tank fill outlet.
    in other words, the deck fill is just a straight drop into the tank.
    I snaked it out just to be sure.
    so it’s likely the vent line. So far, I’m unable to get a snake of any kind into the vent from the outside. Working on that now
  6. rtrafford
    Vero Beach
    So, then the "sag" in the fuel line is a sag in the vent line? That could be moisture. Suggest removing the vent line from the tank and have it shake hands with some compressed air...
  7. SoCal340
    SoCal340 New Member
    Anaheim, CA
    On our 340 we had to cut out a section of the back panel of the compartment under the sink to access the port side vents. On the STB side, we had to pull out the whole couch that ran the length of the salon. Probably not much help for your configuration, but may give you some ideas.
  8. NYCAP123
    A blast of compressed air could well do the snaking of the vent hose. More than likely some spiders set up housekeeping.
  9. rtrafford
    Vero Beach
    That's my thinking. Either the reported sag has captured some condensation buildup or the vent itself is all buggered up. Blast it out with air, blowing out and not into the tank.
  10. MBevins
    MBevins Senior Member
    Windsor On. Canada
    You said you were snaking the vent line. You are aware that there is a screen at the hull fitting so "things" can't get up there.
