Click for YF Listing Service Click for Abeking Click for CL Yachts 99X Click for YF Listing Service Click for Ocean Alexander
Plugged Flybridge Drains on my 1977 43' Double cabin
Discussion in 'Viking Yacht' started by Kdog, Jul 24, 2014.
  1. Kdog
    Kdog New Member
    Tampa Bay
    My Flybridge deck drains are plugged. Any suggestions on how to unplug them? I used high pressure water but that did not work.
    Good shop vac from above. I hope you did not use high pressure from above.
  3. Kdog
    Kdog New Member
    Tampa Bay
    The drains look to small to get enough suction with a shop vac. I use just hose pressure in one drain and water came up the other drain. Where do these drain to? Do they tie into another drain?
    Maybe T'd below the deck.
    Shop vac one drain and plug the other(S). Small lines will clog with small items over time. Removing backwards (as they pile) is the first path to take.
    I'm sorry I can not offer the schematic of your plumbing. Your event is not unheard of in anybodys ship. Work backwards when drawing a drain line.
  5. NYCAP123
    Why not just snake them with a wire hanger?
  6. Kdog
    Kdog New Member
    Tampa Bay
    Unplugged the Drains
    I found that the hose going the overboard drain was crimped I replaced it and all is good.
  7. sbu22
    sbu22 New Member
    New Orleans
    Kdog - if you're still out there - where are the FB drains? I'll be durned if I've seen them on my 76 43 DC.
