Click for Westport Click for Walker Click for Burger Click for Abeking Click for Ocean Alexander
Painting the hull black?
Discussion in 'General Yachting Discussion' started by jesid123, Oct 1, 2016.
  1. jesid123
    jesid123 New Member
    Its time to have the hull painted. Its currently painted hunter green (43 foot Grand banks) The wife wants it painted black. My concern with a black hull is the maintenance.
    She says whats the difference between black and dark blue? (she has a point)
    Has anybody had any experience with a black hulled boat?
  2. Pascal
    The darker the color, the more any ripple in the gelcoat will show. I have seen many black boats that look like have terrible glass work even though sister ships look fine in white.
    If you are down south and paint it black, be prepare to upgrade your air con system...
  3. YachtForums
    The lapstrake hull on a Grand Banks should help conceal irregularities in the gelcoat, but as Pascal noted dark colors tend to magnify any imperfections, plus it shows every drop of salt. I'm a fan of flag blue hulls, but your wife makes a good point. My question would be... does the color justify the increased maintenance?
  4. Bill106
    Bill106 Senior Member
    Beaufort NC
    There shouldn't be any maintenance differences between the two but the black will show everything, water spots especially but also ANY unfairness in the hull surface, especially if your painter lays down a really smooth finish with minimal orange peel and high DOI (Depth Of Image). Many owners are surprised when repainting a gelcoat hull thinking it was smooth and fair already, the higher gloss of a good paint job often reveals "thangs" that went unnoticed.
    If she's had several years of outdoor sun with the Hunter Green, she should be finished with any post cure so you likely don't have to worry about that. To help the significant expense of a repaint last to it's fullest potential I recommend you specify in your requests that she be sanded, primed, and sanded again before topcoating. Using the topcoat manufacturers primer will give you warranty coverage and a solid base the new paint can adhere to much better than scuffed gelcoat.
  5. jesid123
    jesid123 New Member
    Very useful info - thanks everyone!
    Go with Awlcraft 2000 so you don't have to wax it.
  7. GhostriderIII
    GhostriderIII Senior Member
    Newfoundland
    Hunter Green looks cool. I have a tar coating and I hate it, but it does cover up the dings from barges and docks.
  8. GFC
    GFC Senior Member
    Tri Cities, WA
    If mama ain't happy, ain't nobody gonna be happy.
